Well, I bit the bullet..........
I took my car to the dealer and had a new shifter put in my 05. And they did the headlight recall. I thought I was getting off cheap- $525.00 for the shifter job. Then they put the car up on the hoist to do an inspection.
A leaky rear axle seal- it was blowing fluid all over the back end. (That took my bill up to almost a grand.) And of course the dreaded oil pan gasket was bad. Yes I got under the car myself and saw it.
So yesterday they did the first two jobs and I told them I would bring it to do the oil pan gasket. I didn't think it was that bad. Just where it had stained the front with dirt sticking to the oil. I have NEVER seen any oil on the floor but there was a tiny drip on the corner of the pan.
I had to do the rear end seal because I have no idea how much fluid was gone and it probably needed changed. So............ I'm not that worried about the oil leak. And it has never gone down on the dip stick. But I will take it back and have it done in a few weeks.
I guess I'll be waiting for the harmonic balancer next.
Thanks for listening to the rant.
Received 2,887 Likes
I know how you feel. Last month I changed my oil pressure sending unit. Last week my shiter cable broke. Today I noticed my lights will not turn off. Ordered a sensor today. Car goes in for cable and transmission filter/fluid in the morning.
Worst run of luck in the 10 years I have owned it.
Received 3,626 Likes
2016 C6 of Year Finalist
31K...my mechanic attributed some of the seal problem with low mileage on the car, I (and the previous owner) just didn't/don't use it enough. And I got under mine with the mech, although it looked very nasty down there he topped it off for me (couldn't do the job right then) and it only took half a quart so I wasn't in critical territory yet.
Had the rear seals (all 5 of them) changed on my '05 recently, it is quite a labor-intensive job, good news is you get the new differential fluid added, it has additives in it. I suggest you also get a 4 wheel alignment, depending on which seal(s) you had replaced a good section of the rear has to come apart and it throws the rear end alignment out, mine was out quite a bit. Oil pan gasket, are you losing oil? Do you add any between changes? Mine has a slight seep too but I don't add any oil so I'm leaving as is for now, any change and I'll have it done.
When I first bought the car, one of the mechanics told me that because of the aluminum oil pans expanding and contracting differently than the engine- even a new car oil pan gasket can leak. But this is the first time I have seen a (minute) drip on the bottom of the engine.
Pro Mechanic
Received 3,952 Likes
just bad timing for a variety of things to happen at once...............
don't be trying to steal the baser who represents that group as a rebel with a cause for the GS'er crowd..............
Pro Mechanic
No I don't add any between changes. I don't see any on the floor and I keep a piece of white metal siding on the floor under the engine so I'll notice any leaks. But nada.....Nothing.
if anything, the oil pan retaining bolts may have "relaxed" a bit from the original torque values, and allowed some seepage or wicking to start...........
you may want to see if the bolts can be re-torqued, clean the area, and then see what happens before spending the money on a gasket replacement............................
just sayin'................................
I just can't do the things I did when I was 20. Sometimes I get hip pains just getting into the car.
<br /><br />Right. I have been considering the bypass/wire back deal now for about a year now. But I went ahead and took it to the dealer. You might need to know, I'll be 70 in September and just sitting in the car seat, working on something like that- I get horrific leg and hand cramps, back pain, etc.<br /><br />I just can't do the things I did when I was 20. Sometimes I get hip pains just getting into the car.<br /><br /><br />
Saving grace is they are all relatively harmless and inexpensive.
would be hard to imagine that an aluminum oil pan and an aluminum block have different material properties which allow for different rates of expansion.................
Edit-I keep a drip pan under my car too, first car I've had to do that to since my old mid-50's/60's Chevy's...
