Can anyone help me find what options my 2007 has?
Hello, I just purchased a 2007 Corvette yesterday the car is pretty loaded, I am trying to get a full list of my optons/rpo codes. There is no sticker in the glove box at all, and honestly looks like there never was.Is there any other place it could be? Does anyone know if you can get a list by using the vin? Below is my vin.
Thanks!
1G1YY26U775106064
Thanks!
1G1YY26U775106064
Are you sure about that? Several forum members have reported not finding one until we insisted it was there. It should be on the inside and pasted to the glove box door, on the extreme left side of the door.
Look again.
Look again.
As I recall, if you can't find the sticker - mine is there, though you have to stand on your ear to see it (2008) - you can use your VIN to get the original order sheet (from the National Corvette Museum), and also you can get it from a Chevy dealer. Before I learned about the sticker, I called my local dealer and with the VIN, he was able to email me a copy of a sheet with the RPOs for my car.
Good luck!
Good luck!
I had an easier time photographing mine with an iphone than I did actually seeing it well enough to read it.
I found it, its very dark like a silver sticker I guess I over looked it
AAB
AG2
AJ7
AL0
AQ9
BGR
BS1
CJ2
C2L
DD0
DD8
DL5
D42
FE3
FE9
GMB
1L3
J55
KA1
K63
LS2
MYC
NK4
NT7
N37
QX3
R6K
R6P
R9N
SLM
UJ9
UK3
US3
UV6
U2K
U3U
U52
U65
VA5
XND
YTK
Z51
1SZ
3LT
311
313
83U
AAB
AG2
AJ7
AL0
AQ9
BGR
BS1
CJ2
C2L
DD0
DD8
DL5
D42
FE3
FE9
GMB
1L3
J55
KA1
K63
LS2
MYC
NK4
NT7
N37
QX3
R6K
R6P
R9N
SLM
UJ9
UK3
US3
UV6
U2K
U3U
U52
U65
VA5
XND
YTK
Z51
1SZ
3LT
311
313
83U
AAB
AG2
AJ7
AL0
AQ9
BGR
BS1
CJ2
C2L
DD0
DD8
DL5
D42
FE3
FE9
GMB
1L3
J55
KA1
K63
LS2
MYC
NK4
NT7
N37
QX3
R6K
R6P
R9N
SLM
UJ9
UK3
US3
UV6
U2K
U3U
U52
U65
VA5
XND
YTK
Z51
1SZ
3LT
311
313
83U
AAB
AG2
AJ7
AL0
AQ9
BGR
BS1
CJ2
C2L
DD0
DD8
DL5
D42
FE3
FE9
GMB
1L3
J55
KA1
K63
LS2
MYC
NK4
NT7
N37
QX3
R6K
R6P
R9N
SLM
UJ9
UK3
US3
UV6
U2K
U3U
U52
U65
VA5
XND
YTK
Z51
1SZ
3LT
311
313
83U
RPO - Description
AAB
Memory - Driver Convenience Package
AG2
Adjuster Pass ST - Power, Multi-Directional
AJ7
Restraint System - Seat, Inflatable, Driver & Pass, FRT & Side
AK5
AQ9
Seat - FRT BKT, Luxury
AR9
Seat - FRT BKT, Deluxe
AU5
Lock Control, Entry - Remote Entry, Low Power
AU8
Lock Control, Entry - Remote Entry, Specific Frequency
AX4
Restraint Conversion - Seat, Man, European
BAG
Parts PKG - Export
BGR
Plant Code - Bowling Green, KY, USA
BV7
Bumper Provisions - FRT & RR, Canadian Requirements
B4H
Modification - Noise Control, Export
B4P
Modification - Noise Control, Transmission Control Module
CC3
Roof - Hatch, Removable Panels, Plastic
CE4
Washer - Headlamp, High Pressure
CF7
Roof - Sun, Removable, Non-Transparent
CJ2
HVAC System - Air Conditioner FRT, Auto Temp Cont, AUX Temp Cont
CM7
Roof - Convertible, Folding, Power
CW1
Country - Korea
C2L
Roof - Package, Dual Removable
DD0
Mirror O/S - LH & RH, Remote Control, Electric, Heated, LT Sensitive
DD8
Mirror I/S R/V - LT Sensitive
DL5
Decal - Roadside Service Information
DL8
D42
Shade - RR Compt
EXP
Export
FE1
Suspension System - Soft Ride
FE2
Suspension System - Ride, Handling
FE3
Suspension System - Sport
FE4
Suspension System - Special Ride & Handling
FE9
Certification - Emission, Federal
F55
Chassis - Continuously Variable Real Time Damping Magnetorheological
GME
Ornamentation - Extr "GM" Mark of Excellence
GB9
Label, Limited - Consignment - Delete
GM8
Axle Rear - 2.56 Ratio
GU6
Axle Rear - 3.42 Ratio
JAF
Brake Provisions - Europe
JL5
Control - Manual Trans, First To Fourth Gear Skip Shift
JL9
Brake System - PWR, FRT & RR Disc, Antilock, FRT & RR WHL
J55
Brake System - Heavy Duty
J56
Brake System - PWR, FRT & RR Disc, Antilock, FRT & RR WHL, Heavy Duty
KNR
Cooling System - Axle
KNP
Cooling System - Trans, HD
KPS
Cooler - Oil, Engine
KA1
Heater - Seat, FRT
KJ5
Protector - Shipping, Shock Absorber
K05
Heater Eng - Block
K63
Generator - 110 AMP
LS2
Engine - Gas, 8 Cyl, 6.0L, SFI, Alum, GM
LS7
Engine - Gas, 8 Cyl, 7.0L, SFI, Alum, GM
MAE
Marketing Area - Europe
MYC
Transmission - Auto 6 Spd, HMD, 6L80
MM6
Transmission - Man 6 Spd, Tremec, 85mm, 2.66 1st, 0.50 6th, O/D
MN6
Merchandised Trans - Man 6 Spd Provisions
MX0
Merchandised Trans - Auto Provisions, O/D
MZ6
Transmission - Man 6 Spd, Tremec, 85mm, 2.97 1st, 0.57 6th, O/D
NA3
Emission System - Japan
NE1
Certification - Emission, Geographically Restricted Registration for Vehicles up to 14,000 lbs GVW (use 2003 mdl yr)
NF9
Emission System - General, OBD MIL Suppression
NK4
Steering Wheel - Sport Leather
NP7
Steering Column - EEC Approved
NT4
Emission System - EEC 05
NT7
Emission System - Federal, Tier 2
NU1
Emission System - California, LEV2
N33
Steering Column - Tilt Type
N37
Steering Column - Tilt, Telescoping
QL9
Wheel - 18 X 9.5 FRT & 19 X 12 RR, Polished
QG6
Wheel - 18 X 8.5 FRT & 19 X 10 RR, Aluminum, Styled
QG7
Wheel - 18 X 8.5 FRT & 19 X 10 RR, Polished
QX1
Wheel - 18 X 18.5 FRT & 19 X 10 RR, Aluminum, Painted, Flangless
QX3
Wheel - 18 X 8.5 FRT & 19 X 10 RR, Chrome, Flangless
Q10
R8C
Control - Sales Item No. 53
SSG
Graphic - Switch Function Symbol
T62
Lamp System - Daytime Running - Delete
T79
Lamp - Fog, RR
T84
Headlamps - RH Rule of The Road, E Mark
T85
Headlamps - LH Rule of The Road, E Mark
T90
Lamp - Signaling & Marker, Export
UA2
Theft Deterrent Sys - Export Specific
UD4
Alarm - Vehicle Speed, 120 k/h
UE1
Communication System - Vehicle, G.P.S. 1
UH3
Indicator - Low Tire Press, VAR 2
UG1
Opener - Garage Door, Universal
UJ6
UJ9
UK1
Frequencies - Japanese
UK3
Control - Steering Wheel, Accessory
ULS
Lock Control - Steering Column
UL2
Frequencies - European
US3
Antenna - Diversity
US8
Radio - AM/FM Stereo, SEEK/SCAN, CD, ETR, MP3, RDS
US9
Radio - AM/FM Stereo, SEEK/SCAN, RDS, Multiple Compact Disc, Auto Tone Control, Clock, ETR, MP3
UV6
Display - Head Up
U2K
Digital Audio System - S - Band
U3U
Radio - AM/FM Stereo, SEEK/SCAN, DVD, CD, Clock, ETR, Navigation, Voice Rec, MP3
U3Z
Radio - AM/FM Stereo, SEEK/SCAN, DVD, CD, Clock, ETR, Navigation, Voice Rec, MP3, VICS
U19
Speedometer - Inst, Kilo & Miles, Kilo Odometer
U52
Cluster - Inst, Electronic
U65
Speaker System - 7, Custom
U66
VBX
Language Label - Arabic
VDD
Vehicle Information - DVD, Customer Orientation
VA5
Language Label - English
VB1
Label - Shipping, Japan
VC4
Label - Price/Fuel Econ, Puerto Rico & Virgin Islands
VC5
Label - Shipping, Except US, US Possessions, or Japan
VH5
Plate - Vehicle Identification
VK3
License Plate Front - FRT Mounting PKG
VL4
License Plate Front - FRT Mounting PKG, EEC
VL6
License Plate Front - FRT Mounting PKG, Japanese
VZ3
Label - Mercury Disposal Notification
V73
Vehicle Statement - USA/Canada
V76
Hook - Tow
V78
Vehicle Statement - Delete
V87
Vehicle Statement - Gulf States Organization
W11
Navigation Disc Data - Nav Data 1
W12
Navigation Disc Data - Nav Data 2
XFA
Tire Front - P275/35ZR1 8 BW TL HW4 EMT
XFV
Tire Front - P245/40ZR1 8-88Y BW HW4 (EMT)
XGN
Tire Front - P245/40ZR1 8-88Y BW HW4 (EMT) HI - Performance
YFJ
Tire Rear - P325/30ZR1 9 BW TL HW4 (EMT)
YFX
Tire Rear - P285/35ZR1 9-90Y BW HW4 (EMT)
YGJ
Tire Rear - P285/35ZR1 9-90Y BW HW4 (EMT) HI - Performance
YF5
Certification - Emission, California
Z5X
Mirror Provision - Arabic Language
Z49
Export - Canadian Modify Mandator Y base Equip
Z51
Performance Package - Handling
1SA
Package - Option 01
1SB
Package - Option 02
1SE
Package - LZ Option 05
1LT
Package - LT Option 1
1LZ
Package - LZ Option 1
2LT
Package - LT Option 2
2LZ
Package - LZ Option 2
3LT
Package - LT Option 3
35T
Top Color - Gray Beige (05)
37T
Top Color - Titan Gray (05)
41T
Top Color - Black (96)
Received 3,611 Likes
2016 C6 of Year Finalist
Good info here. As midnight said, take your vin to any GM dealer (service or parts) and ask them to print the VIS and build sheet. They are free.
Also, for more info on your car:
http://www.corvetteactioncenter.com/...007/index.html
Your RPO codes:
83U is the exterior color Atomic Orange
313 is the interior color Cashmere
3LT is the option package code - not sure what all is included with this
