2005 C6 rear end cluncking
Good Morning everyone i have a 2005 C6 with 40k that i purchased a few months ago now that weather has changed for the better i am driving it much more.
I am getting a cluncking noise (similar to old school bad u-joints)
mainly noticeable at slower speeds and 1st. or 2nd. gear,, shifts smoothly
no vibrations or shutter on highway..it is just very annoying.
has anyone else had similar noises,,maybe just being ****
any guidance would be much appreciated
if it's while your making sharp turns at low speed, change you diff fluid, if it's happening in a straight line, it sounds like your "couplers" which replaced the u-joints. HEY nannies was that OK? informative? not rude? helpful? I don't get banned?
Yep, being an 05, and the fact that there was a change in the diff fluid used shortly afterwards to keep the diff quiet, could just be the diff fluid needs to be changed. Hell, if the car has been pampered, may just need to drive it on the harder side to allow the diff clutch packs to flush clean instead.
Also, could be the axle nuts loose that that bolt through the wheel bearings. Hence there was a respect on the torque after the first year runs as well.
With 40k, could just be worn sway bar end links making noise as well. Hence end links tend to last about 40K before they need to be replaced due to noise.
Really, just need to get the car on a lift to figure out where the noise is coming from to start with.
Jerry0 (05-22-2017)
i am thinking it is couplers,, really noticeable when taking off from slow stop or shifting slowly.. or if i pull clutch in a slower speed or let off gas at slow speeds are couplers big job assume like everything else they are.
appreciate your opinion
Good Job , And you sounded really sincere.......WW
I have a new to me 2005 also with 40K on the clock. I am experiencing something similar, my "clunk" is definitely when I am shifting. I can't yet figure if it's the couplers, something to do with the clutch or the axle nuts. My wife has a 2013 SS Camaro with the LS3 and it also has the flex couplers. You can make that car do something similar when shifting into 2nd and I know the couplers are not worn out on it. I don't profess to be an expert at driving a manual and I think there is a "technique" to shifting smoothly, especially into 2nd gear.
I have a 2006 and have the same thing happening. Very clunky like a slackness in the driveline somewhere when shifting. If I shift a certain way it wont do it, but if I push in clutch and slowly shift, hesitating before releasing clutch (wish I could explain better) it will be clunky when driveline re-engages with motor. Anxious to find out what happens when you get yours checked.
Cruising
clunking
Received 3,611 Likes
2016 C6 of Year Finalist
I have a 2006 and have the same thing happening. Very clunky like a slackness in the driveline somewhere when shifting. If I shift a certain way it wont do it, but if I push in clutch and slowly shift, hesitating before releasing clutch (wish I could explain better) it will be clunky when driveline rengages with motor. Anxious to find out what happens when you get yours checked.
Retired & lovin' it!
The two causes of a rear end "clunking" noise in an '05 (and later years) that are easiest to address are loose rear axle nuts & OEM differential fluid with insufficient friction modifier. To check the axle nuts, remove the rear wheels & use a 33mm socket to check the nuts for tightness. If loose, re-torque to 140 ft lbs. This is a temporary fix only. The axle nuts are torque sensitive & if loose, should be replaced with new nuts. P/N is 10257766....they are only a couple of bucks each at any dealer. Proper procedure is to remove the old nuts; clean the spindles; apply Loctite 272 (hi-temp red); torque new nuts to 140 ft lbs; allow to cure overnight before remounting tires & driving.
The proper gear oil is Dextron LS Gear Oil, p/n 88862624....2 qts required. Drive car to warm the diff oil; drain & refill. IMPORTANT - drive 8-10 slow speed figure 8's to force the new fluid into the clutch packs. Both of these procedures are easy DIY. Only then if the noise continues should you consider other possible causes.
The proper gear oil if Dextron LS Gear Oil, p/n 88862624....2 qts required. Drive car to warm the diff oil; drain & refill. IMPORTANT - drive 8-10 slow speed figure 8's to force the new fluid into the clutch packs. Both of these procedures are easy DIY. Only then if the noise continues should you consider other possible causes.
Much Appreciated
Jerry0 (05-27-2017)
