Leather wrapping some interior panels
Keev1414 (12-05-2021)
#143
its proving to be very challenging, im only doing very small sections at a time and allowing that to dry before moving on. With all the curves, you need to pull the leather tight and smooth it out.
Keev1414 (11-21-2021)
#145
Sub'd !!!!
#146
Received 8,908 Likes
I’ve got some pieces coming from J-F Customs as well. Can’t wait
#149
How much do these leather pieces you're ordering/installing stretch? It seems to me they put seams where sometimes they're not really needed, especially if the leather is stretched.
The way the seams standup and the backside vee notches telegraph thru is unattractive and unacceptable to me! Doesn't look factory to my eye. Has anyone applied a backer/filler, possibly a thin foam padding to fit up to the underside seam flap to lessen the seam raising up so much and the notching telegraphing thru? How do the big boys/factory do it?
cmonkey713 (06-03-2018)
#150
#151
The one area that I think they could have done without the seam is on the upper door panel. That's where the material behind the seam shows through the most. I wouldn't put foam behind it. I think that would make it worse.
I have been thinking about doing the upper section on the door again and trimming the extra leather back. I may even remove some material from that portion of the door. I watched a few youtube video's but for the most part, the seams followed the curves of the door so you would avoid the issue all together.
Here's a few photos from the door frame trim. I didn't pull or stretch to much on these.
#153
Yeah that was probably mine. I don't think there were too many trying the door panels.
I would say that it hasn't been something that anyone has pointed out at the car shows. I don't think most people even notice but when I get some time, I am going to see if I can't give it another try. I'm pretty confident I can hide that seam better. I haven't had this issue with any of the other items I've wrapped.
#154
#155
#156
I just received my order from J-F Customs: center console, console lid cover & radio bezel. The radio bezel pieces needs lots of cutting for various items like the traction control button, shifter, cup holders, vents & radio. Any tips from those who have done this piece - I don’t want to screw it up.
#157
I used some glue dots to position the leather on the trim pieces first. Once I had it positioned how I wanted, I started trimming a little at a time using a very sharp razor.
On that piece, once positioned, you might be able to trace the cut from the back of the console before making any cuts. You want to leave enough material to wrap the leather around each opening though.
Remove the glue dots and start gluing. (I did this a section at a time)
That's how I would go at it. I am curious how others went about installing it.
#158
Rather install tips
I didn't install that piece on my vette but I did have to cut some of the leather to fit on what I did install. I'm sure others will weigh in on your specific piece.
JABCAT (06-04-2018)
#159
Finally completed interior redo....
Now I don’t feel like I’m sitting in a hole since most of the suspension wires were broke. Used .047” music wire to restring.
#160
Does anyone still have their order information for the rear door sill? J-F Customs is telling me they don't make it and wants me to send them my trim pieces so they can custom make it. Pic below to show the part I am talking about.
