Dumb mistake, simple answer please
Sunday I changed the oil on my 07 Base. I put in 6 qts of oil, I know now it's suppose to be 5.5 qts. Do I have to remove 1/2 qt or should it be ok?
The reality is 1/2 quart extra won't really hurt. If you are uneasy, the easiest way to drop the level is to remove the oil filter and drain it, then reinstall. That will get you pretty close.
Thanks, that's what I thought, I just didn't know if 1/2 qt extra will do any harm?
I did the same thing last oil change. I just left it as is. No problems at all.
Received 2,887 Likes
Wont hurt a bit. As mentioned above GM recommends an extra qt when racing.
Unless you are completely draining (leaving the container upside down in the funnel for a long time) or using a measured fill station, you are not going to get 6 full qts. from 6 one quart containers anyway. I always dump 6 containers in knowing I am only getting around 5.5-5.8 qts. depending on my patience and the ambient air temp that day.
For the wet sump this is no problem.
If you are concerned, however, buy a cheap turkey baster and suck the oil out from the oil fill cap opening.
If the oil fill location is in the valve cover, there aint much oil to be found up there when the engine isn't running and if it leads to the crankcase you'd have to have a pretty long baster.
I have an '07 Z51 auto which doesn't have the oil cooler that the additional 1/2 quart is supposed to be for. I always add 6 quarts because it is easier and neater. Always comes out perfect on the dipstick. Plus or minus a quart isn't going to hurt anything.
