Can I jack from these points?
Hiya, planning on swapping out to a catback exhaust soon. Can I lift just the rear, one side at a time, with the jack lifting ONE point (red circles) - then putting jackstands where the pucks go. Not jacking from the center - just using the jack with nothing above it such as wood or crossbrace.
Just to be clear:
1. Use jack to lift left side crossmember, put jack-stand on left-side car under puck.
2. Use jack to lift right side crossmember, put jack-stand on right-side car under puck.
Thanks!
Just to be clear:
Thanks!
crystallinity (06-09-2017)
Just curious why it seems to be a lot more popular that it is lifted from the center with wood/brace then jackstands under there, instead of the method I plan on doing it.
Thanks. Then why do people use wood/crossbrace and lift from the center? Is it solely for putting jackstands under them on the sides then?
Awesome, that's good to know - thanks again. Is this the same deal on the front as well?
Yes to some degree. It will lift both sides but will start to lift off the rear on the same side, so you will have to do one side at a time in front. I always do the rear first though not only because the entire rear will go up enough from one lift spot but also because I'm lowered and the jack won't fit under the front without driving on wood on lifting rear first.
2020 C6 of the Year Finalist - Modified
Can I jack from this point
When installing cat back you will have to take the x pipe off at the front to get enough room to take off the OEM cat back. Also the rear sway bar inside bolts removed to swing the sway bar down to clear getting the mufflers out and the new ones in. A bit of work but not to bad.
No worries. I wouldn't use the pucks, just hook one side of the c hook on the top of the stand into the holes on the frame, doing that along with blocking the front tires and it can't go anywhere.
NSF
Thanks for the input.
I see, so need to lift the front as well to swap the catback?
Just to be clear:
Thanks!
Just to be clear:
Thanks!
Received 2,061 Likes
I've had the back end up 100's of times and never used a cross bar. I change wheels at the track real often. Just jack up the center of the cradle and both sides come up evenly to put jackstands either on pucks in the shipping slots or on the cradle or just to change both rear tires.
Although I've never checked the height on the front, I don't believe there is enough clearance to get a cross bar under the cradle. I'm quite sure I can't get the jack in from the front when the back is supported on the rear shipping slot locations.
I'd also never attempt to put a jackstand at the shipping slot location on one side and then jack up the opposite side, since during the process there would only be two points supporting the car, not three.
When I need to raise the entire car, I raise the front on one side and put a block under the front wheel, then do the same for the opposite wheel and finally raise the entire back end. and either use blocks or jackstands there. If I need to remove all four wheels, I can get the jack under from the front to remove the blocks and put in jackstands. It may take a bit longer, but it's far more stable.
@those asking about the crossbar - I do not have one, that pic is from google so I'm not sure about the specifics, sorry.
You say you just lift it from the center of the cradle - do you put anything there like wood or do you just use the jack directly on the center? Seems to be general consensus on here that can cause damage - not sure myself.
I've jacked the rear of mine up a few times from those same points. Bought the Harbor Freight cross bar. Its solid and mounts right up to my jack.
