DiabloSport inTune i2 - BLOWOUT - WQL
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
BLOWOUT
for 1999 - 2017 Corvette
Save $100
Get your inTune
with
(Domestic Orders Only)
Limit 3 per Customer
While Quantities Last
Corvette inTune i2 BLOWOUT SALE
...and YES we can do
(PM for Below)
Chrysler - i2010
Ford - i2020
Jeep - i2012
CARB (California) i2050
(PM for Below)
Chrysler - i2010
Ford - i2020
Jeep - i2012
Regards
Chip
•Add Horsepower, Torque and Fuel Economy to your vehicle without even popping the hood!
•Featuring the latest generation ARM processor. The device's display has a higher resolution screen and an exceptionally responsive touch pad.
•DiabloSport's pre-loaded tunes are dyno and street tested to ensure optimal power and drivability gains. Basic installation, big power gains!
•Easy tune asks you for what octane gas you want to run, if you've changed your tire size, if you want to remove the speed limiter and more. It's the perfect way to drop a tune on your ride in minutes!
•Start off with DiabloSport's preset performance tunes and make changes that suit your performance needs. Adjust options like timing, fueling, idle, speed limiters, rev limiters, tire size, gear ratios and more.
•The i2 retrieves diagnostic data of how your vehicle's tune is performing. Export all of your data to a PC and play it back on DiabloSport's Data Viewer logging software.
•Regardless of whether you purchased an i2 for a Chrysler, Ford, or GM- you can buy an additional license to tune ANY vehicle supported by DiabloSport!
•Update your i2 software on virtually any computer- Mac, Windows, Linux. Update times are faster than ever, even large updates only take about 5 minutes.
•Holds up to 5 custom tunes. Use our worldwide network of CMR tuners to step above our canned tunes.
•Touch Screen
•Data Logging
•Check Clear DTCs
•5 Volt Data Logging Inputs
•Accepts Custom Tunes from CMR
•Performance/Diablo Tune 20HP 25TQ
•87 Octane Performance Tune: 18HP 23TQ
•Calibrate Speedometer for Gear Ratio
•Calibrate Speedo for Tire Size
•Cooling Fan Control
•Fuel Rich/Lean Adjustment
•Spark Timing Advance/Retard
•Idle RPM
•Top Speed Limiter
•Rev Limiter
•Shift Points
•Shift Firmness
•Torque Management Adjustment
•Disable Active Fuel Management
•Disable Skip Shift
•Fuel Injector Calibration
Regards
Chip
Originally Posted by CCA Corvette Parts
Here is the complete feature list
•Touch Screen
•Data Logging
•Check Clear DTCs
•Idle RPM
•Top Speed Limiter
•Rev Limiter
•Shift Points
•Shift Firmness
•Disable Skip Shift
Regards
Chip
•Touch Screen
•Data Logging
•Check Clear DTCs
•Idle RPM
•Top Speed Limiter
•Rev Limiter
•Shift Points
•Shift Firmness
•Disable Skip Shift
Regards
Chip
Received 1,636 Likes
Originally Posted by TorchRedFred
On the list you will see "shift points" and "shift firmness". I think that is your trans tuning options.
Ok, this is the way I understand it to be. You have the tune options to tune your engine. Then separately, if you choose to, you have the options to tune or adjust shift points and firmness. I just got my Diablo tuner and used it yesterday for the first time but I have the manual trans. In another thread, I have heard that the guys with the automatics really like the trans options and the Diablo is much more rewarding for the automatic drivers.
CCA Corvette Parts (08-22-2017)
C6 of Year Finalist (stock) 2019
What is the difference between this i2 and the i3. And is the i2 the newest programing or outdated now or can you update it to the i3 or latest. I have heard that it has to be updated and that is not fun...
New design - customizable tune.
I2 is still supported with updates (easy download), not compatible with i3
Regards
Chip
