C-6 vert question
C-6 vert question
Hi All, Does anyone know if the pull down latch assembly for the tanneau (sp) cover on a C-6 vert is the same assembly that GM uses on other models for things like trunk pull downs....hatch pull downs...etc ? I need the switch off the top of that assembly, but can only seem to find a switch for the trunk pull downs and hatches. The assembly looks the same, but not sure about the wire plug as far as matching. Any help appreciated....Thanks.
