Clone Tech2 purchased-Very pleased
Old 07-12-2017, 07:29 PM
  #41
J.Moore
J.Moore's Avatar
The Tech2 is still a great scan tool for many more years yet. As the years go by it will become obsolete but that is in the future as it will always scan OBD1, OBDII, CAN GM vehicles thru 2013. It's software is updated as far as it will get.
As many have already said, 1,2 or 3 trips to the dealer for a scan and it paid for itself already.
Old 07-13-2017, 08:54 AM
  #42
madmatt9471
Support Corvetteforum!
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Subscribed!
Thanks,Matt
Old 07-14-2017, 12:45 AM
  #43
vettedawg2
vettedawg2's Avatar
Sign up for the coupons and get $10 off too. Just paid 239.99 with free shipping using that link in this thread. Hope to have the same luck!
Old 07-14-2017, 03:06 AM
  #44
PCMusicGuy
PCMusicGuy's Avatar
Very true. If you have the dough though, you could get the MDI 2 and handle from 1996 to present and beyond.
Old 07-14-2017, 09:25 AM
  #45
pickleseimer
pickleseimer's Avatar
St. Jude Donor '12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
I would like to learn more about what a MDI setup would look like. The Tech2 does the job for 4 of the cars I own plus a couple more in the family, but I also have two others that are MDI.
My questions are:
1) What's the hardware setup? From what I read, it's an MDI-2 module and a Windows-based PC.
2) Does this setup have some functionality when operating stand-alone like the Tech2, or does it always need to be connected to TIS2WEB or some other subscribed service? From what I've read, you need to have a subscription for the calibration files, but it is not clear to me that a MDI system will operate stand-alone and what the scope of those stand-alone functions are.
3) Subscriptions. I see there are short-term, relatively low-cost subscriptions available for calibration files. Not sure if I need a subscription just to hook the system up to a car.
Comments appreciated from anybody who has some experience. Not intending to hijack the thread - someone was bound to mention the next generation of GM scan tools.
Old 07-14-2017, 09:47 AM
  #46
dmaxx3500
dmaxx3500's Avatar
Received 1,183 Likes on 748 Posts
all tech2 scanners are made in china,even vertronics
real'' ones
a mdi,is just a pass-thru device for programming,you need gm software on a laptop,and pay extra to get a tech2 screen on it,a tech2 can be used in pass-thru also [its in the first set-up screen]
a tech2 will do 100x the things anybody elses scanner will do
ive used a real tech2 and several clones,they are almost the same [looks wise],and they function the same[clones seem to run a little slower]
you need to use them a lot to understand everything they do,start by going into every sub group you can everytime you use it,and start reading ''live data'' ,it will teach you whats right and whats wrong with a running car/truck,
Old 07-14-2017, 09:49 AM
  #47
dmaxx3500
dmaxx3500's Avatar
you can by thru ''dhgate'' too they are just like ''alliexpress''
Old 07-14-2017, 10:32 AM
  #48
CSixDude
CSixDude's Avatar
What is a TS2000 and what is the USB to RS232 cable used for? Is this for upgrading the firmware on the Tech 2 itself?
Old 07-14-2017, 10:54 AM
  #49
RC4G
RC4G's Avatar
I have tried to pay for order 3x using AMEX gift card and keep getting the same payment error:
The card is registered with my name and address. Anyone else have this issue with AMEX prepaid card?
I've left a message requesting to use PayPal in case its a card issue but have not received a response.
Old 07-14-2017, 10:58 AM
  #50
J.Moore
J.Moore's Avatar
The TIS2000 disc has the software to let you connect with a GM server to DL files if you were planning to reflash modules on your car. Can be dangerous if you aren't careful. Also you can view and operate the Tech2 screen on a laptop and view movies, snapshots you recorded when it was connected to your car full screen on your laptop.
Connect it with the 232 cable to laptop. Won't need to update firmware for Tech2 as most all the sellers offer the latest and last upgrade it will get. 33.004 for GM.
Old 07-14-2017, 12:51 PM
  #51
Icecap
Icecap's Avatar
I was pleasantly surprised to come home yesterday afternoon and had my Tech2 sitting on my doorstep. A great looking unit and I played with it most of last night so thanks again J. Moore!
I have noticed a couple of things so far. The TIS2000 DVD wont run on my Windows 10 laptop since it wants to run on an old version of MS Internet Explorer. Is it essential to be able to use this disk since I was able to read the *.pdf files on the provided CD?
Another thing I noticed is that the various interchangeable cable adapters require an insane amount of force to couple together. It took quite a while before I worked up enough courage to successfully couple them. It was actually afraid at one point that I was going to break something trying.
I'm looking foreword to connecting this device to one of the 2 GM vehicles in our fleet and playing with and exploring its functions.
Old 07-14-2017, 04:06 PM
  #52
J.Moore
J.Moore's Avatar
Icecap.. cool you got yours,, yes, the connectors are a tight fit at first. The little metal tang locks them together and after you connect and disconnect them a few times they loosen up a bit. Just be careful and don't bend or break the pins.
I'm running the TIS2000 on Windows 10 thru Oracle VM VirtualBox running Windows 2000 and works fine. I can't take all the credit though as my son installed it and set it up. He's an IT geek. He didn't have any problems with the install though.
You don't have to install the software on the disc as the instruction manual for the Tech2 and the TIS software is online by itself. You don't need it to use the tool on your cars either but I always want to get my moneys worth and wanted to see what all was on the 2 discs.
You'll need a serial cable to connect the Tech2 to a laptop too and use the beige adapter unless your PC has a serial port. I got a Tera Grand USB2.0 to RS232 Cable adapter with FTDI Chipset off Azon. Actually I ordered the wrong one with the male thumbscrews, should have got female screws but I made it work.
Icecap (07-14-2017)
Old 07-14-2017, 06:36 PM
  #53
poughkeepsie
poughkeepsie's Avatar
I've been debating between the tech 2 and the snap on solus. Does anyone have experience with both of these?
Old 07-14-2017, 10:37 PM
  #54
C6ToGo
C6ToGo's Avatar
Received 1,108 Likes on 690 Posts
The power of educating yourself:
I watched the bidding on a Used Tech 2 on eBay last week. Didn't mention it was a clone but pics showed the bogus serial number that all of them have.
It sold for $405 + 17 shipping.
72greg (10-11-2019)
Old 07-14-2017, 10:46 PM
  #55
C6ToGo
C6ToGo's Avatar
Some guys are getting outdated $80 refurb laptops that have a serial port and Win XP....the setup that the Tech 2 uses. Use it only for TIS2000 software.
I couldn't get my CANdi module to be recognized. Started wiggling connections until it did. Hopefully not a bad sign of possibly early failure. Appears to be either the VCI that connects inside, or the cable that attaches to it the VCI.
Icecap (07-15-2017)
Old 07-17-2017, 06:04 PM
  #56
Icecap
Icecap's Avatar
I have had my Tech2 that I ordered as a result of this post for 2 days now. I have played with it and read the documentation and by coincidence yesterday afternoon I logged a DTC and my check engine light came on.
Earlier in the day I spent several hours cleaning and detailing my engine compartment so it looked like it just left the assembly line. I wondered whether I dislodged a plug or something in the process but couldn't see anything obvious.
Hooked up my new Tech2 and scanned for codes. Can't remember the actual Fault Code but it indicated "High Intake Air Temperature". I cleared the code, took it for a 20 minute drive stopping for gas on the way home and it has stayed off so far.
Tech2 is an invaluable tool and what I saved by not having to go to a dealer today just partly paid for it.
Old 07-17-2017, 06:50 PM
  #57
J.Moore
J.Moore's Avatar
Cool, if the code comes back you'll know it is worth investigating. Alot of cars will set a phantom code when there really isn't anything wrong. I've had cars do just that.
If you got the engine or a connector wet that could cause it. Sometimes I'll detail my engine compartment with a light mist of Armour-All and spread it around with an old soft paint brush. Just the plastic surfaces not the actual engine. Haven't had any codes set from it.
Used my Tech2 on my daughters 09 Cobalt yesterday. RF tire sensor is dead. Shows 0 but tire gauge shows 35 psi. Tech2 won't calibrate TPMS and I didn't think it would but I wanted to see anyway. Funny, her car had 3 history DTC's for a radio receiver error. She said radio and CD play fine. I dunno.
It's nice to have the Tech2 so you can look down your cars throat and up its butt so to speak.
Icecap (07-17-2017)
To Clone Tech2 purchased-Very pleased
Old 07-18-2017, 03:12 PM
  #58
keithd
keithd's Avatar
Does anyone know where to get the $10 off code? When I went to the AliExpress site, all I saw was a $1 off $200 or more... woo-hoo.
Old 07-18-2017, 09:55 PM
  #59
Reggied
Reggied's Avatar
Default Removing the F55 options
My vette has the F55 options "Magnetic Selective Ride Shocks". I want to upgrade to aftermarket shocks. I need a Tech II to remove the option from my car to prevent the error codes. I wonder if this device can perform this for me.
Old 07-18-2017, 10:33 PM
  #60
Dcasole
Dcasole's Avatar
Received 2,236 Likes on 1,630 Posts
Reggied, email me thru the forums ...
Dave
Quick Reply: Clone Tech2 purchased-Very pleased
