Clutch slippage
Clutch slippage
Hi all, does anyone else have a problem with your foot slipping off the clutch pedal when it is wet? I have a 2013 grand sport convertible with the metal pedals. Even my new sneakers don't help.
Sam
Sam
I don't think a Corvette is the only vehicle where the clutch pedal will be slick when the driver has wet shoes. One generally has to be what is called..."very careful" ..not to let said foot slip off of pedal.
Yeah, they are absolutely awful. I had several close calls because of it. I ended up getting these:
http://www.ebay.com/itm/GM-19155308-...t/152451334682
I'm sure you could probably find them a little cheaper. Solved the problem entirely for me. They look much better too!
My car would have to be out in the rain for me to have wet shoes, which does not happen.
You can get different pedals that have raised grips that should help.
I took 2 large round head bolts and with a dremel tool cut 2 more slots in the top, so the top looks like an asterisk. The bolts have lengths that just get them through the holes in the clutch pedal. That keeps my shoes from slipping off when wet.
Yes it is dangerous! Just be careful! My complaint is not so much the slippage, but the fact some of our shoes or sneakers have cleat like bottom and its difficult for my foot to slide to the side when changing gears. I have my "corvette sneakers" that I wear when I drive her! I had to shave some of the bottom of the sneaker a little to get it smooth. It works!
Have a nice day!
Have a nice day!
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
Have a nice day!
Have a nice day!
Sounds like something one shouldn't have to do, but that IS an excellent idea---have a towel to wipe off feet so they don't slip off the pedals.
Agreed the clutch and brake pedal are both very slippery with wet shoes. There are a lot of different covers for the pedals available.
I like these but wrong color.
