Tail Lights, Moisture and Dirt
Old 07-18-2017, 08:11 PM
cadyshac
cadyshac's Avatar
Default Tail Lights, Moisture and Dirt
Anyone ever tried or considered drilling a small hole in the body behind each of the 4 tail lights to let moisture drain away? I am on my first 'vette and I removed the tail lights so I could clean all the dirt that had accumulated behind and under them. While I had the lights out I thought about drilling a small hole to allow water to drain instead of laying there forever, but I only thought about it!
Old 07-18-2017, 08:13 PM
bartsky
bartsky's Avatar
They make some pretty good seals for them...
Old 07-18-2017, 08:17 PM
cmonkey713
cmonkey713's Avatar
Received 1,239 Likes on 910 Posts
Common fix for the dreaded taillight issue. We used to do it all the time on C-5's which have the same problem. There are also taillight seals available from several forum vendors that will seal the taillight assembly to the taillight opening prevent water and dirt from accumulating under the light assembly. I would recommend using the seals instead of drilling a hole in the rear facia.
Old 07-18-2017, 08:25 PM
cadyshac
cadyshac's Avatar
Thanks guys, I am new to 'vettes and didn't know about the seals, will definitely check it out.
To Tail Lights, Moisture and Dirt
Quick Reply: Tail Lights, Moisture and Dirt
