Tire presure increase
07-25-2017, 03:30 PM
13 c6 base
Will set tire preasure at 32 in morning. Later driving at 70 to 80 mph tires will rear 40 plus.
Is this normal?
Anything to worry about?
Thanks all
07-25-2017, 03:37 PM
Pressures will always rise from cold temps to hot temps. 8* rise is quite a bit but if it's hot enough it's not unbelievable.
07-25-2017, 03:39 PM
mine usually jumps up to 38-40 after driving in the texas heat.
07-25-2017, 03:48 PM
Thanks all
Headin to bullhead city az area. Last long trip was to Texas in winter when noticied the increase.
07-25-2017, 04:44 PM
St. Jude Donor '15
Pressure increase, especially in hot weather, is normal.
Is 32psi cold what your car tires are supposed to be though?
07-25-2017, 04:45 PM
Realize, also, that the TPMS is not accurate to 1 psi.
07-25-2017, 05:16 PM
Quote:
Originally Posted by
prlwng
13 c6 base
Is this normal?
Thanks all
Look at the tire. What does it say the maximum allowed pressure is? Are you getting a reading over that pressure? If not, everything should be okay.
07-25-2017, 05:20 PM
St. Jude Donor '06-13,'16-'17, '19
BigMonkey73
30psi is the correct cold tire pressure.
Expect 1psi increase in tire pressure for each 10 degree increase in temp.
Tom
07-25-2017, 07:10 PM
prlwng
13 c6 base
Is this normal?
Thanks all
Are you getting the reading from the DIC?
07-25-2017, 07:22 PM
prlwng
13 c6 base
Is this normal?
Thanks all
set them at 30 cold and you are fine
07-25-2017, 09:54 PM
8 p.s.i. is a big jump. Your air supply should be "dry" with as little moisture as possible.
07-25-2017, 10:07 PM
St. Jude Donor '11-'12-'13-'14-'15
Tom
Mad*Max
30 psi cold.
