locking in park
cruzkowski (07-30-2017)
C6 of Year Finalist (stock) 2019
Here's a longer thread with several fixes. I assume the one with the switches is the root cause, no matter how else you get it to shift out of park.
https://www.corvetteforum.com/forums...use-found.html
There are several threads and videos on how to tie back the cam lock on the shifter which is a permanent fix for the problem. There is an actuator in the shifter mechanism the goes bad. You can replace the actuator, which is a PITA or just tie the cam lock in the shifter back to bypass the actuator
