Detailing my exhaust tips
Easy way to clean and polish exhaust tips. Wanted to share this fast and easy process hopping it can help you. They may be easier ways but this worked for me bc it was on hand!! Harbor Frieght buffer with a 3" hock and loop wool pad and three inch backing pad.
Well huh....I tried that and mine just turned black. What did I do wrong?
What compound r u using! Two things come to mind. How long has it been since the tips have been clean. It's important to use a abrasive and polish. That's why I like #83. Cleaner-polish diminishing product. You also could be polishing the carbon build up. Steel wool with some brake cleaner, something to break down the carbon. Once you get it clean then it's a snapp to touch up. Hope this helps
Damn hotrod...that looks amazing. Good stuff man.
I'm currently getting a new exhaust installed. Because I was tired of cleaning\polishing the mufflers on my old setup. I decided to have the new one ceramic coated before install. So hopefully with some soap and water. It should always look brand new.
This is what i use on my Borla tips after cleaning the carbon out.I used
this when i was in the Military in the 60ths..(It was in a can back then) I also use it on my rims and they shine like a baby's ***..Lol
Cherokee Nation (08-04-2017)
NSF
Received 3,066 Likes
2021 C6 of the Year Finalist - Modified
Here is a little tip ...
If your exhaust tips are really dirty, before getting the metal polish out ... Go to Lowes and buy a bag of '0000' super fine steel wool and get most of the crud off first before using the metal polish.
hotrod03 (08-05-2017)
Also works great on glass. I spent two hours "slicking up" the glass on a 1995 Nissan 300ZX Twin Turbo I got about 6 weeks ago. After some Rain-X it's great! The steel wool took off all the old water spots, etc. with no scratches.
Turbo6TA (08-05-2017)
Another very good metal polish for stainless exhaust tips ...
The following 2 users liked this post by Turbo6TA:
hotrod03 (08-05-2017),
O C Charlie (08-12-2017)
GIG is up.
Yeah just funnin'....You have to admit...I had you goin' for a little bit there....
And credit due...Nice work you've done man!
And credit to NSF....That Plasti-Dip REALLY works well Bobby. Still holding up after months.
Not So Fast (08-05-2017)
