Gas Cap issue?
Gas Cap issue?
Car threw a P0455 code after a check gas cap notice showed on dash. Put new AC Delco cap on. Reset code. It is fine until fuel level drops below half a tank, Then same gas cap notification and then engine code. Any ideas?
I had my local shop (oil change joint) do it. I think it was $30 for the part and 1/2 hour labor ($75 total).
The EVAP consists of the gas cap and the EVAP unit that behind the left rear. Check the full read out on your codes. Even Autozone can give you the read out.
I had the CEL come back on after I changed the cap and the EVAC. I would have it switched off and it would come back on in a few weeks. I put in a new battery and it went off immediately and hasn't been on since.
zzjakect (08-17-2017)
