Lower Valence Crack
Lower Valence Crack
I've got a crack in my lower valence. It runs about 4" from the air dam, up towards the front. It's not visible unless you get under the car. I didn't do it, but, I believe it was done when I had my Vette inspected. My question is, is there's any type of glue, that, I can use to glue it back together. I drilled a small hole where the crack ends, so, that it wouldn't keep going. I really don't want to replace the whole front bumper just to repair this crack. Like I said, it's not visible without climbing under, but, I know it's there.
Race Car Tech
I had some fairly deep scapes under mine when I got it. I used a dremel and "V" grooved the deeper ones, filled them in with epoxy, sanded primed and painted with a GM paint code mixed spray can and one would never know it was scratched, and besides no one looks under there unless you are in a car show with mirrors under the car.
Good Luck in whatever you decide on the fix.
