Wood For Jack / Jackstands
Hello all,
Please take it easy on me. This is my first time using wood in between the car and the jack / jack stands. Is there any specific type of wood I need to buy from the hardware store to do the same as the pictures attached?
I'm a little worried about the wood cracking or splitting especially when used with the jackstands.
Thank you.
Thank you.
Exactly! Be afraid. It has to be a hardwood.
I recommend a hockey puck for use on the jack cradle - use only one puck max.
Using wood is ok imo if you don't stack blocks(they easily can slip - I know -it causes a lot of damage).
Marc08EX (08-21-2017)
Marc08EX (08-22-2017)
2x10 or 2x12 pine. There are several threads on how to make ramps, or pieces for using the jack with. Use the search option, or if you can't find it, send me a msg. I have made them before.
Worked well and I felt safe using wood this way. As for picking up front or rear I used
two pieces of yellow pine. The measurements being 2"x 6"x 24" that were screwed together lengthwise.
Doesn't have to be hard wood at all. As a matter of fact, sometimes the softer wood works best because it kinda lets things "dig in" and keep a better grip. Now all this of course goes with the fact that the wood should be big enough so as it spreads the load of some of the delicate pieces underneath the car. I use a piece of 2X6 pine that runs the entire length of the front cross member (or what ever one prefers to call it)......
Thanks for the replies everyone!! This is awesome!
Thank you for the pictures!!! They're perfect.
Do you use the same wood between the jack and the car's jack points as well?
What kind of wood did you use?
2023 C7 of the Year Winner - Unmodified
2018 C6 of Year Winner
Hello all,
Thank you.
Thank you.
This photo you show is one I took probably 10-12 years ago when I first built these wood crossmembers or cradles. They are fir and I am still using the same pieces without any cracking or splitting. I place my floor jack in the middle and jack directly on the wood without any problems.
Marc08EX (08-23-2017)
