H.B.* Finally bite the Bullet
So after grabbing breakfast yesterday I noticed a lot of water coming from underneath the car and a sizzling sound when I parked in the garage, turned out to be the water dripping because of the humidity, right on top of the headers collector.
So then I thought I better take a look at the HB as it did have a little wobble before. Well now its worse, much more so IMHO, so I just ordered the Power Bond PB1117SS from Summit (best price) and new belts, bolt, and seal from GMParts Center on line, quite a savings over my local GM dealers price. QUITE A BIT !!!!!!!!!!!!
So the job will be happening next week hopefully, not by me thou, a local reputable shop
Wish me luck, I get nervous when some one is going to be doing things to my car
NSF
Oh and as a footnote, the owner said he couldn't guarantee it wouldnt wobble again if we used the OEM part, I told him I bought the Power Bond unit and he said great, it will be perfect then
NSF
Good luck! This is next on my list. Let us know how it goes. What bolt did you get?
Hey Bobby - You've got this handled. You'll be better in no time. Powerbond you've chosen is a good one. I've used same on my boosted app. It did the job.
Best,
Best,
ARP $34
OEM $4 (my stealership wanted $10.72)
All in all with shipping& tax I'm in at $307, plus estimate of $600 for labor comes out to $907
Stealership quoted me $1091 using the GM balancer that we all know is a piece of **** plus whatever they would have charged me for new belts and seal, probably another $150 on top of the $1091
If it all works out then I'll be a happy camper, this damn balancer situation has kept me up at nite
NSF
Dragon Tamer (09-05-2017)
That labor quote is pretty good - my shop is at $800. I'm not sure about using the GM bolt though - think I will still go with the ARP unit. Parts cost at Summit/GMParts is a good deal.
Thanks for the reply.
The GM bolt is fine. Only draw back is it can only be used once, which I don't consider a big deal at all. Make sure your installer knows the proper torque for the GM bolt. If I recall, it was 36# plus rotating an additional 140 degrees. As long as he gets the proper torque, you will never have to worry about that HB again.
Sometimes I look at mine just to watch it spin smoothly.
The following 2 users liked this post by HBsurfer:
Dragon Tamer (09-06-2017),
Not So Fast (09-05-2017)
Bruze (09-05-2017)
Plus if the owner of the shop doesn't like the OEM bolt I can buy the ARP right around d the corner LOL only out $4
Just turned 30K Bruce. It had a very slight wobble when I first checked it about 2 years ago, its now worse and I don't want to chance it since I can definitely see it has increased. If it were the same I would probably leave it.
NSF
Bruze (09-05-2017)
NSF
I have that question written down to ask the installer. In another thread one member said just turn up the pressure on the big air impact and call it a day, to which I asked has anyone ever done that and then checked torque values Those big impact wrenches hit hard as hell so I was wondering ???
NSF
NSF
Received 1,136 Likes
NSF
NSF
No, No.No. do not do that, a sure recipe for failure. Find correct spec, it's a certain torque plus so many degrees. Garage rattle gunned mine and it came loose within a couple of weeks.
NSF
NSF
Not So Fast (09-06-2017)
Received 1,636 Likes
NSF, could this possibly be a good time to do the cam you have been considering?
