Techron Ratio
It is corrosive to certain types of metals, but not to any that have been used in fuel systems since the early 1990’s. It is mildly hygroscopic, but modern gas tanks exclude most air, so that is of little consequence. It can phase separate if it contains some dissolved water and then cools off, but so can “pure” gas. There is precisely and exactly the same probability of this happening with and without ethanol. The only slight difference is that if ethanol is present, somewhat more water can separate. But since you have a problem if any water separates, this is hardly a huge disadvantage. It only burns hotter in a carbureted engine where its presence leans out the mixture. In a fuel injected engine where the ECM varies A/F ratio to maintain constant stoichiometry (ie, any car built since 1990), it actually burns cooler, not that that really matters, as it’s a very small effect anyway. And stale after 3 weeks? Where in the world did that come from?
I don’t like ethanol in gas either, but it’s because it requires subsidies and does not provide the alleged environmental benefits. There’s no need to cite crazy performance risks to argue against ethanol. All you do with that kind of argument is allow ethanol supporters to attack the credibility of ethanol detractors.
The following 3 users liked this post by LDB:
Flame temperature is a complex function of not only heat release, but how much the reactants weigh, how fast they burn, whether you are doing it in an open flame or closed container, and if the latter, whether and if so, how fast, the container is expanding. The latter issue gets really messy in an engine because the “container” (ie, the cylinder) is expanding as the piston moves down.
Ethanol has lower energy content, which would tend to drive temp lower, but also needs less air, which drives it higher because there’s not as much air to heat up. But the thing that makes the biggest difference in the example I was citing (ie, ethanol burns hotter in a carbureted engine, but cooler in a fuel injected engine) is yet another factor, namely the rich/lean effect. A fuel injected engine holds constant stoichiometry, which means there is no change in rich/lean when you add ethanol. But carburetors hold fixed A/F ratio, which means if you use a lower BTU fuel like ethanol, the mixture gets leaner. Leaner burns hotter because with the extra oxygen present, the fuel burns faster. That means that even though the ultimate end temp after all the gases are well mixed and going down the exhaust pipe is lower due to the extra air that had to be heated up, the peak temp right as the burning is taking place is hotter.
I have proof of the corrosive nature of Ethanol gas. I have a motorcycle gas tank that formed rust on the top side of the tank from ethanol exposure. Toyota has also published reports of pitting found inside of the fuel rails on some of it's vehicles from ethanol exposure. Once it absorbs water, and it will, the entire mixture becomes corrosive. With regular gas, if water gets in it, the water will sink to the bottom of the tank.
LDB, Thanks for the explanation, it does make sense.
It wasn't me that made the claim ethanol burned hotter though. I believe that claim was in the table presented as alleged facts. In 'Dude's follow up, he doesn't state the age of the vehicles exhibiting rust issues. I was going to dispute the temperature fact until I saw your post, hence the question.
My experience mirrors your claim of less energy with ethanol in FI engines, I found about a 10% reduction in mileage when compared in my LS-3 powered Corvette.
One one of the issues with motorcycles is their fuel systems are not as environmentally isolated as our modern cars. One of the methods I use to help keep moisture out of fuel systems is to keep the tank full and limit condensation to a minimum.
Thanks again LDB,
Mike
Thanks again LDB,
Mike
While I’m not familiar with the Toyota paper you mentioned, most manufacturer studies are statistical analysis of warranty data, and a favorite saying of engineers is that there are lies, damn lies, and statistics. So about all we can say on causality with certainty is that various plastics, resins, and rubbers used in fuel system components before the early 1990’s were clearly susceptible to attack by ethanol containing fuel. On more modern cars, all you can say with confidence is that differences are not large, because if they were, all would have to acknowledge that obvious an answer. On engines other than cars (such as motorcycles, lawn mowers, etc), while the answers still aren’t clear, there is more room for questioning because their fuel tanks are not as well isolated.
As far as water absorption, as I pointed out earlier, pure gas absorbs water too. Yes, E10 will absorb more, but it’s not true to imply that water drops out of gas without any absorption while it gets massively absorbed into E10.
Thanks again LDB,
Mike
Thanks again LDB,
Mike
On mileage difference, I think all you can attribute to ethanol itself for E10 is about a 3% mileage reduction. But there are other variables in gasoline blending that might get you up to 10% on any given batch. For example, without the extra octane of ethanol, a blender might replace that octane with aromatics, which have higher density and thus more energy per gallon. Regards, Larry
Bruze (10-08-2017)
My 71 Datsun 240Z has exhibited no ill effects from ethanol fuel in the 30 years and 110,000 miles I've driven it. Anecdotal... yes.
Thanks for all the responses
Thanks again.
Rust was found in tank when motorocycle was less than 2 years old. E10 gas is all that has ever been used in it. Tank is kept full all the time. Rust is evident even on internal tubes inside the tank.
There is obviously no point in arguing with you. Don't believe me if you want, I don't really care, but the fact is that E10 gas becomes corrosive when it absorbs water as it holds the water in suspension.
Received 1,136 Likes
Rust was found in tank when motorcycle was less than 2 years old. E10 gas is all that has ever been used in it. Tank is kept full all the time. Rust is evident even on internal tubes inside the tank.
Without that control, how can you conclude anything about the rust?
The following 2 users liked this post by Bruze:
FortMorganAl (10-09-2017),
LDB (10-08-2017)
I cant comment on how this works over time as I new the owning a vette, but I purchase ethanol fee fuel that is 91 octane. Car runs great would it be wise to put an additive in such as Techron?
#33
Fuel
Use of the recommended fuel is an important part of the proper maintenance of this vehicle. To help keep the engine clean and maintain optimum vehicle performance, we recommend the use of gasoline advertised as TOP TIER Detergent Gasoline.
Additives
To provide cleaner air, all gasolines in the United States are now required to contain additives that help prevent engine and fuel system deposits from forming, allowing the emission control system to work properly. In most cases, you should not have to add anything to the fuel. However, some gasolines contain only the minimum amount of additive required to meet U.S. Environmental Protection Agency regulations. To help keep fuel injectors and intake valves clean, or if the vehicle experiences problems due to dirty injectors or valves, look for gasoline that is advertised as TOP TIER Detergent Gasoline.
For customers who do not use TOP TIER Detergent Gasoline regularly, one bottle of GM Fuel System Treatment PLUS, added to the fuel tank at every engine oil change, can help clean deposits from fuel injectors and intake valves. GM Fuel System Treatment PLUS is the only gasoline additive recommended by General Motors.
#34
Received 1,499 Likes
Does anybody know if the GM Fuel System Treatment is identical to Techron?
From one of the secret books only a few of us were privledged to have GM secret in our glove compartments:http://www.c6registry.com/Technical/...tte_owners.pdf Page 5-5
Page 5-7
Page 5-7
#36
Bottom line for me, I use only top teir fuel, shell, BP, Costco. And add stabil marine formula about every fill up, for the .25c per dose if it does half of what it says on the label I'm happy.
#37
Mad*Max (10-10-2017)
