Non-Run Flats, What inflator
I'm running non-run flat tires and what to get an inflator and tire repair kit to keep in the car. What does everyone else have or recommend. Thanks
Dave
Dave
When I had a BMW335i I purchased one from eBay. Around $50. I've never used it but it is in the back of my vette now...just in case.
z76232 (10-11-2017)
Received 1,013 Likes
2016 Corvette of Year
2015 C6 of Year Finalist
I use the conticomfort kit from tire rack
https://www.tirerack.com/accessories/detail.jsp?ID=38
you can find cheaper kits but I liked this one
Received 3,066 Likes
2021 C6 of the Year Finalist - Modified
I can't recommend a tire repair kit, but I can recommend a tire inflator that has been great for me.
VIAIR 70P
1. Quiter than most since it is not gear driven
2. Don't vibrate all over the place
3. Inflates tires fast
4. Long 15 Ft. power cord (plugs into the cigarette lighter socket)
5. Long pressure hose
6. Comes with a nice nylon bag that fits in the rear cargo area cubby hole
7. Cheap price ($30 with free shipping)
VIAIR 70P
z76232 (10-11-2017)
I carry this one in one of my rear cargo bins. I haven’t had to use the flat sealant yet, but I’ve used the compressor and it works very well. If you buy one of these on eBay or amazon, be warned. You’ll save money, but the one I bought on eBay was drop shipped from Amazon and the sealant has a date of 05/08/2013. It’s old. I just bought this about a month ago. They have a shelf life of about 5 years from what I understand. I’d recommend going to your local Auto Zone or similar parts store for this product and get one with a fresh date.
Joe
z76232 (10-11-2017)
VIAIR 70P
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
VIAIR 70P
SLIME market a good, compact unit (I won't say they 'make' one because most of the pumps mentioned previously are just marketed by that particular brand and not made by them). Black & Decker also have a nice one. Both fit in the trunk well along with a tire repair kit. I carry one that is designed for motorcycle use.
I have a ViAir, but it's a different, and more expensive, model than the one shown above. I've only used it to test it, but it fits nicely in the cubby. I got it from Amazon for about $80. It inflates very fast, The speed of inflation appears to be a function of price.
I don't have a tire repair kit. I figure if the issue is so bad that I can't inflate the tire and drive for a while, repeating if necessary, then I don't want to fool with it and will call AAA. A Corvette with a flat tire will almost be sitting on the ground and getting to the problem to fix it would be a challenge.
Received 4,499 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I just replaced my run-flats tire with non run flats.
I bought this from Amazon, and have plug kit.
Also belonging to AAA won't hurt either.
Alone with the tire fix-it kit, you might add a screw driver and pliers. Sometimes the nail, or screw will need a little persuasion.
Stop and Go flat kit. I've fixed two tires with it and no leaks. Easier than changing a tire (once your find and get to the nail).
https://www.stopngo.com/pocket-tire-...ubeless-tires/
I also have a $20 Slime compressor from WalMart. It's a little bigger than a couple of cigarette packs.
or spend the $$$ and get the compressor with the kit
and yeah, get some needle nose or a Leatherman tool to get the nail out and trim the plug end. Throw it in the bag. I ride motorcycles and don't go far without it all in my tank bag.
The Stop and Go works best. The mushroom plugs seem to seal better.
Another vote for Vi air.
IF getting one plugging into lighter, do yourself a favor and have spare lighter fuses handy. I learned.
Pump blew lighter fuse, wasn't a big deal since I was in the garage.
Had I been on a highway/parking lot relying on this thing I'd have been mightily pissed.
z76232 (10-12-2017)
Here's the deal, run the compressor BEFORE you attach the inflator to the valve stem. I like to partially screw it on so that I know it's not cross threaded and back off when I hear the air leak out. Then turn on the compressor and fully screw it on.
Stop and Go is the way to go.
z76232 (10-13-2017)
On the forum recommendation I bought the Viair compressor. I'm going to buy the Stop and Go plug kit. Thanks guys.
Vi Air reminds of the $39 Harbor Freight compressor. It works well. I keep one in my truck for hauling my travel trailer. Not exactly compact and seems way overpriced compared to the Harbor Freight.
z76232 (10-15-2017)
I've carried the Slime pump and the Stop n Go plugging kit on my motorcycle for years. Great products. I experimented on my C5 coupe and learned that looking for a nail/screw/etc. on a flat Corvette tire is tough so I bought a small scissor jack so I could rotate the flat tire. This worked but I couldn't get the jack under the body so I then added a 2" piece of dense styrofoam to drive onto, this way I could jack up the car, find the problem, make the repair and reinflate the tire. Or call AAA. When is enough, enough?
