New Side Skirts Installed
#41
Have any Pictures? I looked at RPI and Josh has good products, but at about 6 times the cost. My car is lowered all the way and the rear bushings cut, so I am a little concerned on just how long they will last. At $129 a pair I can take that chance, but I hate to spend almost $700 and have then destroyed.
#42
For some reason when they are selling out they raise the price so they don't sell. They'll go back down to $120ish when they come back in stock.
Keep an eye here for base fitment.
http://www.ebay.com/itm/ZR1-Style-Ro...72.m2749.l2649
BWF07 (10-17-2017)
#43
It looks like the stores are sold out of the base model.
#45
And a couple at the rear wheel well for the flaps.
Coach Borne (10-17-2017)
#46
#48
I'm twisting and turning about whether or not to use dbl sided tape, screws or rivets Leaning towards rivets, any suggestions anyone ??
Should be here by Monday
NSF
#50
I would also vote for self tapping screws. I had good luck with them when I installed them. Make sure you show us pictures when you put them on!
#51
#57
That's the intended purpose right, hence the name self tapping.
I do know that when we drill a hole in fiberglass, as in boats, for a hole saw anyway, we run the drill in reverse to keep from chipping it out until it gets a groove started, then go into forward
Do you think its necessary to use the same method on these plastic cars
NSF
NSF
#58
I did not drill pilot holes since the screws have a drill bit on them. I didn’t have any problems. I believe the size was 3/16” X 1”. I also used small washers just in case.
#59
NSF
NSF
If you attempt to reverse to start the groove you run the risk of the screw running away from its intended point of contact.
#60
I personally wouldn't reverse these to get a groove started. A self tapping screw isn't nearly as aggressive as a hole saw. Because the leading edge is beveled when the screw rotates in the clockwise direction it will create the necessary groove nearly immediately.
Skirts will be here Monday
NSF
