how do we stop top from squeeking. 2008
Firstly, you post in the correct forum...........
Received 19,233 Likes
'20-'21-'22-'23-'24
Moving to C6 General.
Race Car Tech
Seriously, Welcome to the C6 Forum
As this is a very common issue, it has been posted many hundreds of times over the years, but new members such as yourself should read the FAQ portion on top of the C6 General forum. It has so much info on all that is C6
Here is the thread on Roof Noise from the FAQ section.
https://www.corvetteforum.com/forums...long-post.html
Here is the link to the FAQ section
https://www.corvetteforum.com/forums...9-14-16-a.html
The Video for some of the things that work to quiet it down.
Watch that video it works perfectly and costs less than $10.
Received 1,636 Likes
Also, make sure the rear latch is adjusted properly. There is a small steel hook that comes from the targa top and grabs onto the car when you lock it. That hook is adjustable. I have 2 tops and neither one makes any noise, but I do notice that the rear latch on each is adjusted pretty tight and takes a little pressure to lock it. I'm thinking that helps some. The hook can be turned to make it shorter or longer but there is a little screw that holds and locks it that you need to loosen first with an alan wrench.
