Marrad ST3 Racing Seat Install with Stock Seat Belts
Old 08-27-2018, 02:10 PM
0marrad
Former Vendor
marrad's Avatar
We now also have an option for lap belt holes on our ST3 seat that are large enough for the C5 seat belt retractors to fit thru.
http://www.marradind.com/proddetail.asp?prod=ST3
Old 08-27-2018, 02:30 PM
0marrad
Former Vendor
marrad's Avatar
Here's another seat we just made for a C6 customer.
Old 08-29-2018, 04:01 PM
CTGrandSport11
CTGrandSport11's Avatar
Looking good. Email sent
Old 01-31-2019, 02:03 PM
greynolds
2nd Gear
greynolds's Avatar
Track day (HPDE) seats for C5 Z06
I have spent a long time trying to find the best seat for my C5 given my strict requirements.
I needed seats that:
1. Could be used for HPDE track use with a 5 or 6 point harness
2. Could work for 2 different height and size drivers (needed to be adjustable)
3. Would retain the stock seat belts so that it would be street legal
4. Would fit a 240lbs, 5’11” driver in a C5 with stock interior
After a long search, which included test fitting in other cars, I settled on the Marrad Industries ST3 seat which met all of the above requirements. http://www.marradind.com/proddetail.asp?prod=ST3
I will try and describe my install process below in hopes that it may help others.
I am not a professional mechanic and none of the instructions below are certified safe so proceed solely at your own risk. I am not responsible for any issues or accidents to you or your car as a result of this writeup.
I ordered the revised ST3 in August of 2018. I also ordered the Ultra Low Seat Mounting Bracket (for more head room), The double locking Sliders (to adjust to multiple drivers)and the side seat brackets. I did not order the Harness Mounting from Marrad initially because I bought the 6 point harness and harness bar from a fellow C6 owner upgrading to a C7. (This harness bar turned out to limit seat travel rearward. I had to order the Marrad seat mounting bracket with integrated harness mounting to allow the seat to be adjusted for longer legs)
http://www.marradind.com/proddetail.asp?prod=C5UL-RHM
My Install process experience
Removing the stock seats.
Remove the 2 plastic covers over the front 2 floor studs
Remove the nuts on the front 2 studs
Slide the seat forward in order to gain access to the rear 2 nuts
Disconnect the car battery at this point (to prevent any electrical shorts or accidental airbag deployment)
Remove the 2 nuts from the rear studs
Disconnect the 2 electrical connectors under the seat
After lifting the seat off the studs I removed the seat by angling the seat back towards the center of the car and moving the seat bottom out of the door first.
Bolting the ST3 seat to the seat side rails, mounting base and sliders
My seat base mount, slider and side rails came already assembled
Remove the stock seat belt receiver from the stock seat bracket and attach to the ST3 side rail with a 3/8” x ¾” grade 8 bolt (purchased from local hardware store) The stock nut can be reused.
If you will be using a 5 or 6 point harness, now is the time to attach the sub belt and lap belts bolted to the sub belt bar included with the seat mounting base.
(this took several iterations of testing to determine the length the belts needed to be to accommodate both drivers)
I guessed at the length, then bolted the seat to the side rails, sat in the seat, tested the fit of the belts and readjusted as needed. (installation should be per your harness manufactures instructions)
Because the ST3 seat bolts to the side rails on the side of the bracket it is easier to test fit the driver to the seat prior to installing in the car to adjust seat angle to personal preference.
Once the seat is bolted into the car the tunnel side bolts are not accessible.
Dealing with the 2 rear seat mounting studs that are too short (couple options for this step)
Option #1 Marrad Industries sells stud extenders since the rear stock studs will not be long enough for the seat mount plus the harness mount plus the upper harness bar brace.( basically you will have 2 or 3 pieces of steel sandwiched together to be bolted to the floor.)
And the stock stud closest to the door will not be long enough to get the nut on) http://www.marradind.com/proddetail.asp?prod=M18SEb.
Option #2 Remove the stock 2 rear studs and replace with longer bolts
I chose option #2. (I used 7/16” x 2” grade 8 bolts to replace the studs)
The studs are spot welded to the bottom of the car so I chose to grind the head of the stud off under the car. They can alternately be removed by supporting the area under the car around the stud and using a hammer to beat the stud through the floor.
The area around the stud under the car must be adequately supported in order not to damage the floor of the car while beating on the stud.
This is how the stud heads look under the car.
this is how it looks with the stud heads ground off
Now that the studs are out, I got a piece of 1/8” x 2” x 20” steel (from local hardware store) to us as a reinforcement bar under the car for the back 2 seat stud replacement bolts.
Mark the 2 hole locations on the reinforcement bar by holding the steel bar under the car and having a helper mark the hole locations from inside the car.
Now 2 holes have to be drilled accurately in the steel without the bit walking. The easiest way I found to do this with only a handheld drill is to drill a hole of the same size in a scrap piece of steel and then clamp the scrap piece of steel to the steel to be accurately drilled and then place the two in a vise and drill away
here in the picture is the scrap piece of steel used as a drill bit guide clamped to my reinforcement bar so that I could drill an accurate hole.
It is also best to drill one hole in the steel support then place it under the car and check the marking for the second hole prior to drilling. (this I learned from experience)
Then repeat the process to drill the second hole.
The steel support you just made needs to be painted to prevent rust.
Installing the ST3 seat in the car
The ST3 installs easiest by angling the seat back into the car first then placing the mounting bracket over the front 2 studs.
You will need a helper to hold the reinforcement steel plate, that you made, under the car with the 2 new bolts (locally sourced) are inserted through the accurately drilled holes.
On the inside of the car the 2 bolts should be visible. On the tunnel side of the car a lock washer and nut (locally sourced) can be used to secure the mounting bracket and harness bar (if harness and mounting base are not all one piece) On the door side the bolt from underneath the car will secure the mounting base, Harness bar (if not integrated) and upper harness bar brace. (the stock studs would not have been long enough to attach all 2 or 3 of these items).
this is the view from the back of the seat looking down to the floor
seat installed with harness
Installing the shoulder harness belts
I installed the shoulder belts to the desired lengths and attached to the upper harness bar. (installation should be per your harness manufactures instructions)
Reconnect the battery
Went for a test ride
Observations from the install:
1. Had I known from the start that I would have limited adjustment of the seat rearward with the other manufactures harness bar I would have ordered the Marrad combination bracket/harness bar initially.
This combination bracket/bar with stud extenders would have eliminated the need to replace the stock studs and made the install easier.
this is a comparison of the integrated seat mount and harness bar (foreground) and
the seat mount and other vendors harness bar. (background) notice that the seat will hit the harness bar about 2 inches earlier than with the integrated mount in the foreground.
also with the integrated mount in the foreground there is only one piece of steel to bolt to the floor vs 2 pieces of steel stacked on top of each other in the background.
2. The ST3 Race seat with the ultra low mounting bracket allows me to sit lower in the car giving me extra head clearance with my helmet on.
3. I have not been to the track yet with this new seat install but from all the spirited driving around town the new seat is very stable, fits tight in the car but still allows complete seat adjustment.
4. In my C5 Z06 I have no warning lights on the dash from this install.
5. The seat install was very straight forward after I had all the right parts. So I hope that this write up will help with the planning and install process for others.
Old 01-31-2019, 09:25 PM
0marrad
Former Vendor
marrad's Avatar
You can see the rear harness mount from another company in the top of the photo. Notice that it reaches its full height in front of the rear floor studs. Ours is on the bottom (in this case a welded one piece unit with the ultra low rear bracket) and you can see we have it designed to allow for at least 2 more inches of legroom, since any seat sitting low enough would hit the unit in the upper photo.
Old 01-31-2019, 09:52 PM
0marrad
Former Vendor
marrad's Avatar
The M18 stud extenders were designed for the aluminum rail kits that sit above the carpet. However, they can be modified to solve the problem of the short rear studs in the C5 floor. Normally they install head down, but below I cut the end off of an extender so that it is now threaded all the way thru. If you drill out the holes in the mounting bracket and the foot from the harness bar strut to M18 you can thread this the opposite way and the head will become the head of a bolt tightening everything down.
Old 06-26-2019, 03:53 PM
truggiero19
truggiero19's Avatar
Originally Posted by marrad
I made a link to a package with the ST3 seat and mounting hardware used (ultra low brackets, dual locking sliders, side mounts and seat belt adapters) for $999 below. That will save $128 per seat over purchasing the seat and hardware package separately. The seats with diamond stitched inserts can be requested with the up-charge waived until supplies run out.
http://marradind.com/proddetail.asp?prod=ST3-C6UL
Mark
Any chance of doing something like this again but without the sliders? I'm the only one who drives my car so I dont really have any need for adjustment as long as I have a wide range to be able to mount it in the right spot and leave it. It would also be lighter I assume to not have the sliders. I also like the kit idea so I know I will have everything to put them in a C6 and not be missing any necessary parts.
Old 06-26-2019, 04:47 PM
0marrad
Former Vendor
marrad's Avatar
When sliders aren't needed people use the aluminum rails for installation.
http://www.marradind.com/proddetail.asp?prod=C567MASR
Old 06-26-2019, 05:00 PM
truggiero19
Thank you. So I will just require the seats and aluminum rails for installation? Or do I need the ultra low seat mounting bracket as well?
Old 06-27-2019, 08:07 AM
0marrad
Former Vendor
marrad's Avatar
You would only need the aluminum rails. They do take more work to install because they are designed to sit flat on the floor and there are wiring harnesses under the carpet that may need to be moved around to get the rails to lay somewhat flat. You also won't have as much legroom available because if you bolt a seat in a fixed position it must be placed in front of the rear seat studs so you can get to them to tighten them down. The slider installation shown at the start of this thread is much easier, sits as low and provides more legroom, but does weigh more.
Old 03-25-2020, 09:38 PM
jcbennett
jcbennett's Avatar
Originally Posted by bmalczewski
4. Installing Seats back into Car
Now simply put the whole assembly back into the car and do the whole procedure in reverse:
- Reconnect the seat belt wiring harness
- Bolt down the 4 bolts holding the seat to the floor
- Tighten the bolt to the 15mm nut which now acts as the Seat Belt Anchor to the Custom Adapter on the door side.
- Reconnect the battery
Take your time and make sure all bolts are securely fastened. I kept the bolts holding the brackets to the rails a little lose during the install and tightened everything down at the end.
The fit was extremely tight for me against the tunnel because I have heat insulation material installed on the floor wrapping over the tunnel underneath the carpet. If you have insulation material on the tunnel you might not have full range of use from the sliders.
Quick question for your regarding installation of the floor brackets. Did you run into any issues with the carpet and/or airbag sensor harness in getting the brackets to seat flush against the floor? I've got an '08 Z06 and getting ready to install the Marrad ultra low brackets. It looks like I'm going to have to do some carpet removal and harness rerouting to get the brackets to seat flush against the floor. Would greatly appreciate any guidance based on experience before I start hacking away at the carpet.
Old 03-25-2020, 10:09 PM
GotVett?
GotVett?'s Avatar
Looks great and thanks for posting.
Old 03-26-2020, 09:06 AM
  #33
truggiero19
When I installed my bracket I pulled the harness back towards the door out from under the seat and tucked it under the trim panel.
The carpet was no issue.
Old 03-26-2020, 10:19 AM
  #34
0marrad
Former Vendor
marrad's Avatar
We have the bracket drawn to sit as low as we can get it. Some fabrication shops we've tried have had trouble bending it as low as we have it drawn and some production runs have sat 1/8" or more higher in the back. The shop who made the parts we have now was able to bend it low and sometimes the carpet will need to be trimmed. You can always shim with some washers to prevent that but I'd rather give the customer the option because some need every fraction of an inch they can get.
Mark
Old 03-26-2020, 10:39 PM
  #35
jcbennett
jcbennett's Avatar
Appreciate the reply and tip! Removed trim tonight and took a peak under the carpet. The airbag and seat belt harness was relatively easy to separate from the main harness along the door and I just moved it in between the two seat mounting bolts in front. Gets me a lot closer to mounting the brackets flush on the floor in a Z06.
Old 03-26-2020, 10:52 PM
  #36
jcbennett
jcbennett's Avatar
Mark
Thanks Mark. Completely agree with erring on the side of more headroom clearance. I pulled up the carpet tonight and attempted to to mount the brackets direct on the composite (or fiberglass?) floor ['08 Z06]. Even with the carpet completely removed and the airbag / seat belt harness out of the way, it looks like I'm going to have to shim up the back of the brackets with a couple washers. I removed all of the extra padding / heat shielding from the areas directly under the brackets to get them as low as possible. May cost me ~0.25" of headroom but I think I can still make it work. Will assemble seat to brackets this weekend and hopefully do a test fit.
Old 08-27-2020, 05:53 PM
  #37
asanelli
asanelli's Avatar
These may help visualize headroom gain. The shoulders make the changes obvious. Driver is 6'4" - 250 lbs.
Can this same result be expected from a C5?
To Marrad ST3 Racing Seat Install with Stock Seat Belts
Old 08-27-2020, 06:17 PM
  #38
Dbl_D718
Dbl_D718's Avatar
In my experience, yes. I had mine mounted low enough to touch the carpet in my C5, which gave me enough headroom to finally wear a helmet without hitting the ceiling. I left the seat cushion in and I'm 6'2".
Plug: My C5 seat is for sale here
Old 08-28-2020, 08:04 AM
  #39
0marrad
Former Vendor
marrad's Avatar
Yes
Old 02-01-2021, 01:03 PM
  #40
0marrad
Former Vendor
marrad's Avatar
Here are the first pictures of a new lower bolster version of our ST3 seat. I should have a picture in black cloth in a week or two. They will be added to the site soon.
Quick Reply: Marrad ST3 Racing Seat Install with Stock Seat Belts
