08 with no fobs, what can I do?
Hi guys, I just bought another C6 Corvette to dismantle. I did an 05 a couple months ago and it came with a fob so I was able to run, drive, and test everything on the car before dismantling and selling the parts.
So I bought this 08 LS3 - 6MT on copart and the hauler just called me when he was picking it up to tell me they can’t find any fobs. I really like to run the cars I dismantle so I can be confident in what I’m selling.
I have tons of experience with Ferrari 355 and 360 immobilizers and keep an ignition with key and immobilizers with fobs for each of those cars so if they come without keys or fob I can put mine in real quick and get everything running.
I’m not too knowledgeable on the Corvette yet. I’m willing to buy whatever I need new or used to get it running and tested then will save those parts for any other CY Corvette I get without a fob just as I’ve done with Ferraris.
My question is what do I need? I search eBay and find what I think is the immobilizing unit but don’t see any being sold with matching fobs. Isn’t the unit pretty much junk if you don’t have a fob to go with it? On the Ferrari 355 or 360 if you don’t have the pin or a fob that is mated to the immobilizer then the immobilizer is worthless.
Also does the immobilizer pair with the engine ECUs? On the 355 it doesn’t pair and you can just swap in an immobilizer that you have a fob for and you are good but on a 360 the immobilizer pairs with the left side engine ECU so you have to swap in a clean unpaired ECU for your immobilizer to pair with.
Sorry for all the Ferrari analogies but those are what I know and usually deal with, I wasn’t planning on being faced with this on a Corvette. Any information you guys can provide on how the system works and what I need to buy and replace would be greatly appreciated. And if anyone has a good receiver/immobilizer with a fob for sale please PM me. Thanks.
All you need is a fob and an actual key that comes with the fob. Get them on ebay. You can get any fob from 05-13. It doesn't have to be for an 08. You will need to get the key cut at the dealer. Take proof of ownership and I.D. and they will cut a key according to the vin on the car. With that key you will be able to program the fob to match and start the car. You won't have to replace anything.
DIABLOZ (11-08-2017)
Maybe PM the OP of the salvage flood buy or ask in his thread?
He just did it with no physical key, something about tricking the ecm & using a spare (wife's) fob to program it.
Thanks for the info.
Thanks, I just read through that entire thread. I’m going to order a fob off eBay and send him a pm. Funny, I sold the fobs from the 05 I just dismantled cheap as heck and now I’m probably going to have to pay double what I sold those for to get one. Oh well, just my luck. 😁
I believe the 2008 uses a different fob then 05 to 07.
XX
It's a joke the way they have this setup about needing a key. If you have a fob new or used then you only need access to the inside the car. It could take less than a min, then watch someone drive off in your car.
DIABLOZ (11-18-2017)
Not exactly. There are three 10 minute wait periods before the fob will program. You also need the key to put the car into program mode.
XX
No key needed, and only three 10 minute wait periods -if all four fob's are taken. C6 Fob. Short Procedure 5 times, and a few secs done.
XX
It would be a cool trick to pull on someone you know with a c6. Tell em leave your car open, turn your back when you hear it fire up a min or less then wave good bye.
XX
Well this dumb coon was going to borrow the key cylinder on the wif'es to program her second to the salvage. As I am backing out the second bolt it hit me, like jimmying a door should work.
XX
Anyone else can try it, if someone is close to me I will prove it. Maybe cause they don't know, cars are locked, that's another story though and it doesn't take long that way either.
Ok, here’s an up date. I unloaded the car this morning and started to mess with it.
I got ridiculously exited when I pulled out the floor mats and found a fob from the car. Unfortunately it was a cruel joke and turned out to be a broken case with no electronics inside.
So I put a battery charger on the car and got it juiced up. Nothing would work on the car. When I push the start or accessory button it just says no fob detected. I went through all the fuses in the under hood box and found 3 burnt. I find this is very common with the wrecks I get, they seem to burn fuses upon impact. I checked all the ones in the passenger footwell and found none blown.
Now, I can move the power seats, pop the hatch and gas door, the electric door latches are working intermittently. When I push down on the acc. Button the acc. Only stays on for a second. Like with the windshield wipers on I can push acc. And they will move a little bit, push it again and they move a bit more but the acc. Will not stay on. The stereo,ac controls etc stay dead.
I tried to make it go into program mode for the new fob but when you turn the key 5 times it does nothing. Nothing comes up on the display, all dark and dead.
Are there more hidden fuses somewhere that I might check? Anyone have any idea what’s going on with this thing?
