WHAT THE??? New wheels - Page 3 - CorvetteForum - Chevrolet Corvette Forum Discussion
C6 Corvette General Discussion
General C6 Corvette Discussion not covered in Tech
Old 11-14-2017, 12:12 PM   #41
MYCoupe
CF Senior Member
MYCoupe's Avatar
Quote:
Originally Posted by choppychop View Post
It’s amazing how many people will reply without reading the entire post...
Unsubscribed
Not sure what your issue is, but I have been reading this entire thread from the beginning. I was merely pointing out to the OP that I went from his previous setup to his current one without any issues when it comes to tire diameters. Not sure what is so hard to follow about that for you...
MYCoupe is online now   Reply With Quote
Old 11-14-2017, 12:42 PM   #42
weathermaker
CF Senior Member
weathermaker's Avatar
Would it be foolish to swap out 1 at a time and drive it around the block and see if 1 of the tires are the culprit?
weathermaker is offline   Reply With Quote
Old 11-14-2017, 01:34 PM   #43
cgladish
CF Member
Support Corvetteforum!
cgladish's Avatar
Default wheel
Quote:
if you haven't already, why not take them to a tire shop and have the balancing checked? if they check out, then the issues becomes something on the car. at least then you know what problem to chase.
go get 'em tiger!
cgladish is offline   Reply With Quote
Old 11-14-2017, 03:43 PM   #44
Jclgodale3
CF Senior Member
Jclgodale3's Avatar
Quote:
go get 'em tiger!
these are freshly mounted and road force balanced. 2 drives in the subdivision at maybe 1 mile and not over 30mph
Jclgodale3 is offline   Reply With Quote
Old 11-14-2017, 04:01 PM   #45
jkirk1
CF Senior Member
jkirk1's Avatar
Complete guess here, but is there any chance the wheels are not pulling down all the way on the hub? Are the lug nuts closed end and bottoming out before pulling the wheel up tight? Maybe the newer style wheels allow the studs to stick out further from the wheel.
Sorry, just trying to think of anything that may help.
jkirk1 is offline   Reply With Quote
Old 11-14-2017, 04:55 PM   #46
Jclgodale3
CF Senior Member
Jclgodale3's Avatar
thank, ill take any possible solutions at this point. I️ am, however, confident the lugs are pulling the wheels tight to the hubs.
Old 11-14-2017, 11:37 PM   #47
Jclgodale3
CF Senior Member
Jclgodale3's Avatar
Ok...update with no resolution. I put one old tire/wheel setup on the right rear and one new tire/wheel setup on the left rear. Drove it. Same reaction...lurching, hopping under load. Swapped the other new tire/wheel setup on the left rear and got the same reaction so I don't believe it is a damaged wheel or imbalanced tire unless I got lucky? and both rear wheels are damaged or unbalanced.
Old 11-15-2017, 11:22 AM   #48
BigBlok502
CF Senior Member
BigBlok502's Avatar
WAG here (Wild Azz Guess) The tires are asymmetric, are they mounted on the rims correctly? In other words, are the outsides of the tires facing the outside of the rims?
BigBlok502 is offline   Reply With Quote
Old 11-15-2017, 01:26 PM   #49
Jclgodale3
CF Senior Member
Jclgodale3's Avatar
Quote:
yes sir..confirmed
Old 11-15-2017, 01:39 PM   #50
jaredtxrx
CF Senior Member
jaredtxrx's Avatar
Have you gotten the new TPMS sensors calibrated to the car yet? My guess is you with either have to tow the car to get this done or find someone that can come to you.
Do you still have the DIC message about Active Handling? If so have you tried to pull any codes?
jaredtxrx is offline   Reply With Quote
Old 11-15-2017, 05:30 PM   #51
Jclgodale3
CF Senior Member
Jclgodale3's Avatar
hopefully programming the TPMS tonight.
never had a DIC message on “active handling” so not sure what your referring too
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • WHAT THE??? New wheels
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    WTB black wheels mc6z06 C6 Parts for Sale/Wanted 6 02-12-2017 09:37 PM
    Tire sidewalls fun ticket C7 General Discussion 2 02-07-2017 01:16 PM
    WTB CCW's, HRE etc wheels!! canuck9 C5 Parts for Sale/Wanted 6 01-28-2017 11:05 AM
    z06 aftermarket wheel tire size - Stock tire ripped off the wheel 07z51 C6 Tech/Performance 16 02-15-2016 09:59 PM
    Taller tires on Z51 size wheels?? Wm Rose C7 General Discussion 0 02-12-2016 07:12 PM
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    Sponsored Ads
    Vendor Directory
    • Ask a Question
    Question Title:
    Description:
