Window indexing not working! *reindexing*!
My battery died. Charged it with a trickle charger. Battery is fine now. Car starts. Drives around. Been perfect for a week.
But! Windows don't index. Followed about 10 different ways to reprogram the windows. Nothing seems to work.
I just need the top portion of the window to close. Is there anyway to do that manually until the window is fixed?
Get In car (close door), start car or accy position. lower window then raise window. Hold up button up for 3 sec after window reaches top. Release up button then hold button up for an additional 3 sec.
luck.....(door has to be closed!)
I just went through this recently. The window wouldn't quite go all the way up, so indexing the windows wasn't helping. I finally disconnected the battery again and this time the window went all the way up like it's supposed to. Did the index procedure on both windows and all is good...
