Replaced shifter bushings = awesome
My 06 has 124k miles and am assuming original shifter bushings. I ordered “shifter lower housing bushings” from zip for $15 + s/h ($27.50 total).
The shifter was pulling too far to the left so when you went into first or second, it would feel like it was going over a little bump to the right before going into gear. I could work around it, but not the shifting experience I want or expect in a corvette. The bushings were meant to be a stop gap til I could get a MGW, now I am not sure I need one!
I followed instructions on MGW website to remove the shifter. Most difficult part was releasing the electrical clips for the traction control button and the 12V outlet. The clips for cig lighter and hazards switch were easier.
edit: after more thought, I believe the black crumbles are primarily from the bottom of that rubber “mat” that lays on top of the shifter base. I know mine ripped when I pulled it out.
Two things,
If you remove the screw from the front plastic piecce, you can pull the entire rod out of the housing to clean and re-grease the rod in the lower housing.
Yes, you still want the MGW, and it will be night and day how precise the MGW shifter shifts, compared to the OEM unit that feels like it came out of a ford Ferguson tracker with it sloppiness/vagueness instead. Hence it not all about the short throw,since you can adjust the MGW to have as long as throw as you want, but when you are banging down gears, and with the MGW, you now that you are in the correct gear each and every time instead.
Two things,
and just like that MGW was back at the top of the to buy list
Richard F (01-22-2018)
West Coast Corvette sells the rubber bushings which are more like the OEM but better.
http://www.westcoastcorvette.com/p-3...and-sport.aspx
