10s NA Bolt Ons and Stock Exhaust.... Can it be done
Old 04-20-2018, 08:27 PM
  #61
lazerlemonta
lazerlemonta's Avatar
Got my 10s today
Old 04-20-2018, 10:08 PM
  #62
Scotty2000SS
Scotty2000SS's Avatar
Good job Phil!
Old 04-20-2018, 11:42 PM
  #63
mellojoe
mellojoe's Avatar
Nice!
Old 04-21-2018, 02:58 AM
  #64
madmatt9471
Support Corvetteforum!
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Right on man!
Now you must give us a run down of your set-up:
Gears, LT's, Cats, no Cats, X-pipe, A6, Stall Converter, RR's, Mufflers, TB, Manifold, Cam, Tires (for the run) etc.
Many will want to follow your path
Thank you for sharing.
Thanks,Matt
Old 04-21-2018, 08:12 AM
  #65
lazerlemonta
Originally Posted by madmatt9471
Right on man!
Thanks,Matt
Ewp, crank scraper, ati, 1.85, psi1511, rodmod intake, 2”x2 1/4”x3” headers 3” x pipe, flex fuel, 5.5” clutch and stage 2 dif with 4.10s, ram air and ported Tb. 26x9.5x16 QTP, GTO spares.
Old 04-21-2018, 09:35 AM
  #66
Scotty2000SS
So impressive for being in the stock cam and stock heads!
Old 04-22-2018, 04:52 PM
  #67
Mikey Morris
Mikey Morris's Avatar
Nice job Fill!!
Old 04-22-2018, 04:58 PM
  #68
Mikey Morris
Fill are those Hoosier drag radials?
Old 04-22-2018, 08:13 PM
  #69
lazerlemonta
My 10.58@131 pass
Old 04-22-2018, 08:14 PM
  #70
lazerlemonta
Yes sir. 26x9.5x16 QTP
Old 04-22-2018, 09:19 PM
  #71
mellojoe
mellojoe's Avatar
whoa, 10.5? damn
you dropped over half a second from the start of this thread. super nice.
Old 04-26-2018, 11:59 AM
  #72
lazerlemonta
Originally Posted by mellojoe
whoa, 10.5? damn
My first trip to the track it went 12.6@116 but the clutch was slipping from previous owner glazing it I guess. So we modded up and hit the 11s but i did not expect to go so deep in the 10S that easily.
Old 05-22-2018, 12:40 PM
  #73
lazerlemonta
Well I ended up trashing the Tilton clutch. Second gear burnouts and 1.5 60's didnt agree with it. Going to a RPS twin carbon with aluminum flywheel. Hoping it will get me in the low 1.4 60' range and net a 10.3x ET @ 133ish. Still have a stock intake to work on yet too. Other mods I done for the the 10.5 passes were a lithium battery and removed the sway bar. COntemplating dropping the npp mufflers for the next track outing they are 23 pounds each and I could remove the passenger seat to get me in the 30xx race weight range.
Old 05-22-2018, 04:28 PM
  #74
mellojoe
mellojoe's Avatar
Tough break on the clutch, though. More $$$ is always hard to spend, but hopefully this keeps you going strong. The only problem (i'm sure you realize) is that hitting 10.3 or 10.25 is going to put you in dangerous situation. You'll be so close to 9s. Dude, i love it.
40-lbs from the mufflers. Another ... 40? 50? lbs from the passenger seat. That will be near enough to 100-lbs (45-kg) to make a significant difference. You might just be into the 10.2 range. That's super quick, mate.
Well done.
((edit)):
Note, dropping mufflers completely and removing passenger seat makes it less of a pure-street setup. But who cares? You can still literally drive to the track, a couple wrench turns to remove 'dead weight' as is standard for track prep, and make the run. Congrats again on the great numbers.
Old 05-22-2018, 05:39 PM
  #75
lazerlemonta
Well done.
((edit)):
Thanks Joe! I appreciate the interest a few of the guys have in here. Imagine if I could do race brakes, strip the interior, get rid of air bags, drop the mufflers, race steering wheel, no AC, Radio etc etc for sure you could dance with the 9s with stock heads and stock cam. I refuse to do some of these things lol I like having a complete car but I am not against pulling a seat and mufflers for a glory run
Old 08-20-2018, 06:32 PM
  #76
lazerlemonta
Picked up a mid runner fast and NW 102. Car pulls so much smoother and all the way to 7000. Will have dyno result comparison soon....... looking for those 134-135 trap speeds
Old 08-20-2018, 07:03 PM
  #77
gradywhite931127
gradywhite931127's Avatar
😮😮🤭 gotta be a thrill!!!! Interested to see your new quarter time
To 10s NA Bolt Ons and Stock Exhaust.... Can it be done
Old 08-21-2018, 08:48 AM
  #78
madmatt9471
Keeping up with the thread!
Thanks,Matt
Old 08-26-2018, 07:05 PM
  #79
lazerlemonta
Took my car to a local show that had a portable dyno I had been on before. This is not tuned yet but it picked up a solid 25rwhp from 6600-7100.
Old 08-27-2018, 11:11 AM
  #80
madmatt9471
It looks like you added HP and TQ across the board also which is going to pull nicely
Great add on!
Thanks,Matt
Quick Reply: 10s NA Bolt Ons and Stock Exhaust.... Can it be done
