Front panel lifting
This is what you need more than likely. GM Part# 11561329
https://www.amazon.com/Front-Bumper-...70_&dpSrc=srch
11588818/dp/B0040CTUZ0/ref=sr_1_1?s=automotive&ie=UTF8&qid=1522693444&sr=1-1&keywords=GM+Part%23+11561329
I also need to replace these retainers on my 07.I know that this is a old thread; but, I hope you can respond.
Thanks,
Alan Carnahan
The amazon link for this retainer is for GM Part# 11588818....is it the same as the GM Part# 11561329? Do you know? Reading inside the Amazon link and copying the just part of the link... it shows this link for 3 different GM parts....11588818/dp/B0040CTUZ0/ref=sr_1_1?s=automotive&ie=UTF8&qid=1522 693444&sr=1-1&keywords=GM+Part%23+11561329
Thanks,
Alan Carnahan
Thanks,
Alan Carnahan
11561329 Rocker Molding Retainer
11609871Bumper Cover Retainer
Note, I didn't have to remove the entire bumper cover as some suggest when fixing this. I just loosened the screws/clips by the radiator to allow enough flex in the bumper cover to remove the old clip with a flathead screwdriver. Insert the clip and press firmly on the cover and you're done! Just be gentle, but this was an easy fix.
allprohq (08-24-2018)
Pro Mechanic
Received 3,952 Likes
Thanks,
Alan Carnahan
Thanks,
Alan Carnahan
all the information you need is in the link below.....................
https://www.corvetteforum.com/forums...pping-out.html
I am getting ready to undertake this fix. I have the clips (11561329) but am not sure if I will also need the bumper cover retainer (11609871). I think I will take a look and see what it looks like inside first. If all goes well, I should have several left over clips for anyone who may need them.
Both of my sides are lifting but one more than the other. Looking at the picture obviously the clip is broke, do I just pop out what is remaining of the broken clip and pop a new one in?
Pro Mechanic
Yes...…………… be sure to check out the links previously posted in this thread as they contain pictures showing exactly how to remove the old clips too...…………
