BCM replaced on 09
BCM replaced on 09
Hello, I have done a search and read a lot about my issue but could not find the same symptoms, I have a 09 base automatic, the BCM got wet, went to the dealership and bought a brand new one. the issues are it starts without foot on brake, will not come out of park, brake lights stay on all the time, and as far as codes i have a crank relearn, and on the message center I have the service stability and service stabilitrack, also when you turn the headlights on they will barley flicker almost like a strobe for 2 seconds then nothing, take the fuse out for the low beams still do the same and relay is closed? high beam, turn signals all work. If you take the fuse out for the stop lamps and they stay on, took the stop lamp relay out from the passenger foot well, the brake lights stay on? the only fuse you can pull to cut the brake lights off is the 30 amp for " BATT 5", also it will open back up the relay for low beams when that fused removed, the brake lights do not work at all when BATT 5 fuse is removed. I have done ALL grounds under hood per searching internet, I have cleaned and cleaned all connectors at BCM and add dialectical grease. new red top batt, new brake light switch, it is charging, runs great sounds great every other accessories and gauges work flawlessly, I had a idea maybe i got a bad or wrong BCM so i bought one off ebay from a 09 with exact part # and it does the exact same thing? every symptom is the same. It seams to me there may be another module bad somewhere? or ground may be especially since both BCM do exact the same? Anyone have any ideas on another module or a certain ground? And what does the BATT 5 fuse supply power to? what ever it supplies power to, my problem may be in that area?
Thanks in advance
Lane
Thanks in advance
Lane
Thanks in advance
Lane
Thanks in advance
Lane
Thanks in advance
Lane
Thanks in advance
Lane
This is my wife leaving here passenger side window down, not a flood car.
