Do you have your own tire machine/balancer?
After sending my new 19/20 inch (approx. C7 Z06 sizes) performance snow tires to a shop directly from tire rack, bringing my rims, going through 2 weeks of crap because they don't know or care how to mount TPMS sensors and find, learn about, order and install the brackets necessary as well as how to plug the inner holes (an extra valve stem hole on the inside of the rim which, if used for the TPMS or a traditional size valve stem will not clear the tie rod at full lock)
Hearing the shop cry about the width and profile of the rims...this, from 2 separate shops (the first shop tells me they don't want to work with rims/tires of this size) The local "major brand" shops such as firestone/goodyear would not do them either.
Driving around a few times, wasting hours bringing people parts, getting my rims scratched up and then having the balance weights fall off, returning for re-balance...
I have come to the revelation that If I had my own tire machine and balancer I could take those hours wasted and just to it myself.
Maybe I wont get the highest tech or top of the line machines but I'm sure that once I learn how to use them I will balance better than any shop hack who truly doesn't care if my wheels are perfectly balanced or not.
With 4 vehicles and a trailer, I'm wondering has anyone else gotten fed up with tire shops and decided to do this themselves?
I see tire changers that look like a simple post for a couple hundred dollars to a couple grand and then much more.
Received 2,092 Likes
Just checking to see if anyone thought along the same lines and bought their own tools
I share your frustration with most tire shops, but I don't think this is a great use of money and space.
Buy a spare set of wheels instead and have the snow tires mounted *once* at a competent shop. Sometime when it's convenient, long before you need them.
It doesn't take any more room to store four unmounted tires than it does to store four mounted tires. Mounting and balancing equipment, on the other hand, takes too much floor space.
The nice thing about two sets of wheels is that you won't be motivated to put off tire changes. Just switch to the other set whenever you want.
speedz06 (12-16-2017)
Received 2,478 Likes
St. Jude Donor '15
"In honor of jpee"
I frankly doubt it's that little, and that it's worth having if it is. But you can ask Hunter, Coats, etc. They all have reps in every area that supply the machines.
Since '08, I've read about Elite Auto* in Port Jeff serving Setauket, too. They've had a good reputation. I would ck them out and ask questions about your aftermarket wheels, tpms mounting and tires. Don't know where you went to, but this might be the place for you to go. Good luck.
Found website: http://www.eliteautony.com/index.html
Tire machines can be costly, a cheap one can cost you $2k and a balancer another $1.5/2k.
On top of that you will be your own guinea pig and have the risk factor of scratching your rims nor damaging the tires while learning how to properly do it...Oh yeah you might also need a compressor to operate the machines, comes, tools etc.. and a good work space.
Just take it to your local dealer and let them charge you $25 per tire to mount them and balance them, have them do an alignment for an extra $60/80 just to justified their work so they can not give you any run around if the car is shaking, bouncing or wearing unevenly...that way you can always come back to them if any of these matters presents and have them correct it at no charges or excuses from them since they did everything that involves a good ride on the car.
Just my .02
Just my .02
I'm a bit perplexed by your issue, and the fact that the tires are "approx. C7 Z06 sizes". Not sure what that means. In any case, did tirerack send you to Discount Tire? Those are the folks who tirerack deal with around here.
I don't think you will find satisfactory results with a $3K setup. Seems to me that if tire shops can't get it done with far better equipment than you will likely buy, how can you get it done with lower-quality equipment than they use?
I know I didn't offer any helpful advice...just wondering why you are having so much trouble getting your tires mounted.
the problem is the shorter and wider the tire is, the stiffer the sidewall is. it is a MAJOR pain in the *** to mount and dismount tires like this. tire machines that are designed specifically for these type of tire and rim set up cost around 12k. most shops don't have the higher end machines like this and try to get by with a cheaper tire machines. therefore they are higher risk to damage your wheels.
most of the time they would rather pass at making 15-25 bucks per tire to avoid rim repairs at $200 per rim.
Yep, starts off with a machine that is not going to mar the hell out of the inside of the barrel by clamping on it to hold the rim, then you get into a machine that can road balance the tires next.
St. Jude Donor '15
"In honor of jpee"
I've been looking for a changer/balancer for years. I have 8 cars and a trailer, and another 3 cars in the family I take care of. However, the only setup I would consider is a 'no-touch' system that is not rim clamp, and that alone prices me out of the market. Then a high-end balancer to take care of 12" wide rims. Oh well, I do look frequently at used stuff thinking one day I may get lucky.
Received 1,013 Likes
2016 Corvette of Year
2015 C6 of Year Finalist
Just had new tires put on mine, ran around trying to find someone that would install 345's as my old tire shop got sold and new owner refused to do them, even theough they had been doing them for 10 years.
finally Redline Motorsports told me about the tire shop they used near my work, so I pulled them off the car, and took the wheels and tires to them. Did a great job and even painted the weights black when they installed them. But no I wouldnt consider doing it myself
