Stick on Spoiler???
Stick on Spoiler???
I have been looking for a rear deck spoiler and was wondering what your thoughts are for "stick on" (tape) spoilers. I am looking for the good, bad and ugly relating to their adhesion, durability, looks etc. Thanks in advance.
John
John
The fit was perfect on one and almost perfect with the other. No complaints from my end given their generally low price. Looks-wise, a lot of it will depend on whoever you take it to for prep and paint. If looking to buy pre-painted, it’s hit or miss. The pre-painted one I had was pretty good thankfully.
For reference...
Johnny125 (01-08-2018)
The double-sided tape (sometimes provided) is extremely strong. I buy and use heavy duty 3m ones as I’ve had great success with them. Make sure you take your time positioning the spoiler as it can be a pain if you don’t get it right the first time. You can spray a little water so you can move it around before it dries and sticks. I’ve had two “stick-on” spoilers (different cars) and they have held up very well throughout the years.
For reference...
For reference...
Received 3,087 Likes
2021 C6 of the Year Finalist - Modified
The factory installs the ZR1 spoilers with mount studs and nuts .... no tape is ever used at the factory
That's how I mounted mine.
_______________________________
Attachment 48331114
Attachment 48335520
Attachment 48333538
Attachment 48331114
Attachment 48335520
Attachment 48333538
I agree. Had the car up to 130MPH+ many times and it’s held. I am however changing mine out for an extended version. Let me know if you are interested in a used ZR1 tape on spoiler in perfect condition less than a year old. It is painted LMB but can be repainted easily.
why not just drill?
if you ever remove the spoiler anyway the paint will be crap.
so its either you have 4 holes on the hatch or a strip of real crappy paint across the back.
because some guys, me included do not want to drill permanent holes in the top of facia. Once the holes are drilled and want the spoiler removed you have to replace the entire rear facia, get prepped and painted. I just like to have the option later if I want it.
I installed the Ron Fellows spoiler on my C6 using the two outer studs and nuts underside and the 3M tape on the ends only. Been on over a year and tight and firm as ever.
If I want to remove it and install the factory short spoiler I can.
If you own a buffer with some compound and know how to use it you can bring the paint/clear right back. Even if you had to wet sand with 1500 grit then compound and buff it's no big deal. I've done it.
I am thinking that the only reason someone would [not] want to drill holes and attach the ZR1 style rear spoiler properly is that they have plans on removing the ZR1 spoiler someday, and re-installing the smaller OEM spoiler.
In my case ... I have no plans on ever installing the small OEM spoiler on my GS again ... In fact, I don't even have it anymore. Might have got thrown in the trash a long time ago.
I had a spoiler on my C5 that used the 3M tape. never had an issue and for those that are worried about harming the paint if you remove it, it is no different then any other item held on with tape. Heat gum and fishing line along with the Goo Gone and you are all set.
I have a ZR1 style sitting in my garage that did not come with the outer mounting hard ware so I am thinking of mounting it withe the existing stock spoiler bolts and tape on the outer part.
I can understand drilling for a permanent install but
Tape gives you a chance to make up your mind or change the mod, holes are permanent.
if you garage your vette 24/7 maybe. otherwise i find it hard to believe that after exposure that the paint could revert right back to original status as if there was never a spoiler installed.
I've buffed, corrected many a paint jobs in my time, BC/CC, enamel, lacquer and have brought many paint flaws, scratches back so you couldn't tell there was a problem.
Now paint correction won't repair deep cuts, scratches or gouges but will work on 90% of paint flaws.
I can understand your thinking and that's fine, I just like to have the option if I ever want to use it.
Randy_in_MD (08-18-2020)
For reference...
For reference...
