Transparent Top Question
Old 01-11-2018, 01:29 PM
HOXXOH
HOXXOH's Avatar
Received 2,061 Likes on 1,505 Posts
Originally Posted by EVRose
Mr. Atoz...I loved that guy!
When I first read the OP's forum name, I thought he might be an old HS friend (class of '59). His name was Richard Anuskiewicz. We just called him Dick A to Z or wrote it A2Z.
Old 01-11-2018, 09:20 PM
Elijah71
Elijah71's Avatar
If you don't want to see the sky go for the shade otherwise I'd go for the tint.
Old 01-11-2018, 10:43 PM
S.C. vette
S.C. vette's Avatar
Originally Posted by SouthBaySurfer
A painted roof was standard; a transparent top(RPO code CC3) was a $750 option; both tops(RPO code C2L) was a $1400 option. You can check the RPO sticker in the glove box to see how your car was originally optioned.
check the sticker on the glove box to see how it was sold by the dealer.
Old 01-13-2018, 02:59 AM
Weasel
Weasel's Avatar
I like my suction cup headliner. It softens the interior sounds.
Old 01-13-2018, 12:59 PM
Torchsport
Support Corvetteforum!
Torchsport's Avatar
St. Jude Donor '15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
Bought my transparent top 3 years ago. Colored top has been under the bed ever since.
And this is from a guy that prefers painted hard tops.
Old 01-13-2018, 01:11 PM
Bruze
Bruze's Avatar
Received 1,136 Likes on 882 Posts
All I've ever had is the TT. If I tried a colored top I would probably feel claustrophobic.
And I would keep looking up for the sun, clouds, moon, etc.
Old 01-17-2018, 04:07 PM
Chase0808
Chase0808's Avatar
If you don't like the transparent top, you could always get it wrapped. Its probably a lot cheaper than buying a second top and you can always go back if you want.
Old 01-18-2018, 12:20 PM
ben z
ben z's Avatar
I only have the transparent top. The build code sticker in the glovebox only indicates that one. Mine has a ton of micro-fine crazing, but can only be seen in bright sun, up close and from a certain angle. My bodyshop guy said he can finish it down then spray it with smoke tint and clear, with a flex additive so it won't craze again, says he's done many of them.
Mine came with a static cling liner, which has dot-matrix holes. I have never removed it, and even in FL summer the car is nice and cool but I can still see the sky.
Old 01-18-2018, 12:26 PM
DocktorQ
DocktorQ's Avatar
Originally Posted by cadyshac
I have both tops but have never used the solid color one, I love the lexan top. Get a "static cling" sun shade and use it during the hottest summer months. They are available from several vendors for less than $50 and mine works great. I just remove it for fall, winter, spring and reinstall when hot weather returns. I got mine from West Coast Corvette, like $39 + shipping.
I also have the cling sun shade and it makes a big difference.
Old 01-18-2018, 03:19 PM
BozoBBozo
2nd Gear
BozoBBozo's Avatar
That's a cool (hah!) idea...I never thought of that. I'm guessing you could have it wrapped for under $200, which is certainly cheaper than finding a good condition solid top.
Old 01-23-2018, 08:30 PM
jeffs64
jeffs64's Avatar
Default C2L Option
I'm a nubee. My build sheet says "C2L" Dual Roof Package. So again I'm new does that mean like a Tee top or two piece roof. I know it's painted not Lexan. Thanks in advance
2008 C6 W/ Z51
Old 01-23-2018, 08:35 PM
cadyshac
cadyshac's Avatar
2008 C6 W/ Z51
That means your car came from the factory with both removable tops, body color and clear (lexan). If you only have 1 now then the other went somewhere, sold, destroyed, who knows for sure.
jeffs64 (01-28-2018)
Old 01-23-2018, 08:49 PM
  #33
S.C. vette
S.C. vette's Avatar
Sadly greed takes over at the time of resale or trade-in, in your case the body matching top was sold outside of the car deal.... sadly it may have been damaged thru improper handling and took flight because it was not secured properly and no pre-fight. Replacements show up here all the time, if needing one for summer weather. Good luck, 👍🏿
Old 01-28-2018, 12:27 PM
  #34
jeffs64
jeffs64's Avatar
Default C2L option
When I picked up the car the Lexan roof was in the car so luckily I have both Top's car has 39989 Mile's and is pretty clean. Thanks so much. Jeff
2008 C6 Z51 AT
2010 Ram 2500 6.7L
2014 Chevy Cruz Diesel
Old 01-28-2018, 02:24 PM
  #35
jeffs64
jeffs64's Avatar
Default C2L option Update
2008 C6 W/ Z51
Just picked up the car and it does have both tops I just didn't see it in the pic's on line.
2008 C6 Z51 AT
2010 Ram 2500 6.7L
2014 Chevy Cruze Diesel
curve65 (01-28-2018)
Old 01-28-2018, 05:06 PM
  #36
tprice
tprice's Avatar
Originally Posted by Mr Atoz
Has anyone bought the suction cup sun shade? Does it work?
Michael
I have, works great but honestly I don't keep in there
I would also agree with this, does seem to make the ride a lot quieter
I have the color matched top as well and I have never put it in and neither did first owner
Quite honestly I kind forget about it
Old 01-28-2018, 06:58 PM
  #37
Gman in NC
Gman in NC's Avatar
I ordered my C6 in 2005 with transparent top only. It was about a $750 option when you sacrificed the original painted one. Never looked back. If I was ordering one today it would bel the same way.
FatsWaller (05-28-2018)
To Transparent Top Question
Old 05-28-2018, 11:01 AM
  #38
GibAholic
GibAholic's Avatar
Originally Posted by Elijah71
Guys Guys Guys & Gals.
If you have the transparent top and like the open view I strongly suggest that you go to a tint shop and check out a CLEAR tint they have that literally appears to block almost all of the heat from the sun.
It is a 3M product line called Crystalline.
3M claims that all films in the Crystalline line reject 99.9 percent of UV radiation and 90 to 97 percent of infrared radiation.
I just picked up a transparent roof and will be taking it in to get the Crystaline tint on it.
I would have done it also on my car windows but on the C6 due to the large curved rear window nobody will do it because it is a thicker film.
Check the Heat Test
I wanted to get mine tinted with an IR blocking film, my tint guy would not do it. Unless the tint adhesive is specifically designed for acrylic/polycarbonate the adhesive will PERMANENTLY bond with the plastic. The roof will offgas and cause bubbles between the adhesive and tint, you wont be able to remove the adhesive, top trashed..
Old 05-28-2018, 04:33 PM
  #39
Pilgrim86314
Pilgrim86314's Avatar
Originally Posted by Bruze
FWIW: I love my transparent top! Yes, it gets hot inside when parked, but driving a few hundred yards with the windows down will expel most of it, then close the windows and crank the AC up.
A ride at night with the moon out is really nice.
As far as I know, if you ordered it new with the optional trans top, then that's what you got. If you wanted a second top you would have to buy it.
To me, sitting in a 'Vette with a painted top is too much like being in a cave. Obviously, others don't see it that way.
Pilgrim
Old 05-28-2018, 11:09 PM
  #40
DezVette
DezVette's Avatar
Check the Heat Test
I have this on all 4 windows. It does a great job at keeping the heat out, and if I get the transparent top, I will be having it tinted, as well.
Quick Reply: Transparent Top Question
