Realistic HP Gains...
SO been saving over the winter. Starting now to plan what to spend the money one. Right now I have it planned to do Hinson Headers with catted x pipe(800$)..Vararam Intake(375$). I had stock exhaust, purchased some NPP mufflers for $300. Got a Diablo tuner(300$). Not sure how much a custom tune threw DiabloLew would be. But will get a custom tune.
How much HP do you think it reasonable to expect?
About 25HP from the long tube headers,
About 15hp more from the re-tune.
The Vararam intake is not going to gain you any more power, but will prevent loss of power from the engine pulling in hot air that can cause the engine to start to retard the spark advance timing from the hotter air instead.
6hp with the NPP gates open.
About 25HP from the ling tube headers,
"So now the how much power will you get question- standing on a dyno without using any special programming you should expect 10-15hp from any cold air kit,but once moving the VR will put all the lost MAP pressure back into the plenum yielding another 17hp by 60mph 19-20by 90-100mph"
So in a 1/4 mile should add 20ish HP? Adding that, thats around 490HP at the crank.
Received 3,087 Likes
2021 C6 of the Year Finalist - Modified
The A6 cars will lose about 15% HP at the rear wheels ... The M6 cars will lose13%
My stock LS3 / A6 made 371 RWHP (SAE corrected) ... with 15% loss, thats 435 Net HP
Adding Pfadt long tube headers with cats and a dyno tune, it made 405 RWHP (SAE corrected) ... with 15% loss, thats 477 Net HP
So, I got a 34 RWHP increase.
Note: This was using the same DynoJet.
___________________________
I don't have the 'before' dyno sheet, but this is the 'after' dyno sheet:
Attachment 48338516
Attachment 48338516
If you look at the RWHP curve on my dyno chart above, you will see that the HP stopped increasing at exactly 5,500 RPM.
I can't explain that ... I would think that it would still increase slightly on up to about 6,000 RPM.
It just hit a 'wall' at 5,500 revs.
My MN6 2008 whnet from 375 rwhp 381 rwtq to 422 rwhp/rwtq with catted ARH headers and Vararam and a tune.
47 rwhp gain.
Remember all dynos are different.
I saw 400 rwhp/rwtq with just a tune with 800 miles on the car.
47 rwhp gain.
Well the intake helping to full timing from the tune should add some HP. The Vararam website says:
Received 2,061 Likes
Convincingly, Vararam is the CAI used on the quickest cars on the performance list more than all the other brands combined.
I believe my car is almost identical to Turbo6TA on mods, headers, intake shroud, new plugs & wires, Npp and you see his dyno results at 405 rwhp on a DynoJet. Mine was done on a Dyno Dynamics machine, rwhp was 363.1, so don't get hung up on numbers as I did, because I would wager that our 2 cars in a drag race would be within a fender of one another on any given day
You should get a before and after baseline to really know what you improved with the mods.
NSF
NSF
I think thats enough work done to dip into the 11s. Im shooting for 11.7s Got to stay ahead of them new Mustangs.
Factor in a 3200 converter and drag radials if you are really looking for a 11.7 ...
Dave
Adam, I have the exact mods and tune and I agree it should go 11.7 but now the problem is launch .... our track leaves a lot to be desired at the starting line and the best I have done on street tires is 12.0X with a 1.9 - 2.0 60 ft times , which is not to shabby but ...
Dave
Dave
Get these two correctly tweaked and the motor should be pulling hard to bounce off the rev limiter.
All stock LS-2 motor with such above tweaked, so the motor bounces off the rev limiter with vengeance still pulling hard.
Attachment 48339858
Back to a Cold air intake, and it does not add more power, only preserves the motor from taking it much hotter air engine bay air than the outside temp air, to prevent timing retard isntead.
So when the air cleaner is pulling in hot air from the engine bay, depending on the engine bay temp its pulling in, it can cause the timing to be retarded to reduce the HP levels.
Attachment 48334173
So again, with the parts listed and the tune, here will be his gains,
About 25HP from the long tube headers over the stock exhaust manifolds.
As for C6 base stock motor crank HP,
LS2 makes 411 at the crank,
LS3 makes 436hp at the crank.
I bring this up, since if you dyno the car stock, should be coming up with the correct HP numbers to start with at the wheels, and not someone short pull Dyno'g to make the adds on look like they are making more HP than they really are from the stock motors numbers isntead. Hence if you have a LS2 M6, and is dyno'd stock, the dyno should be showing that the RWHP should be 350hp at redline ASE corrected.
As for Crack HP to wheel HP numbers,
if a M6, then about 61 HP loss from crank to wheels through the drive line.
If a A6, then about 80HP loss through the drive line to the wheels instead. The added loss in about 19HP is due to the torque converter in the automatic transmission.
We know the amount of loss through both drive line systems compared to what the stock motors put out/to what is will dyno at the wheels, and these are fixed numbers losses through both C6 drive lines/trans.
If you add HP to the crank, then the loss through the drive line does not increase, but remains a constant instead (unless you do mods the drive line or gearing, which changes the know constant lose numbers of both the M and A drive lines.
So LS3 / A6 making 371 RWHP (SAE corrected), has the power at the crank about about 451HP (371hp +80hp drive line loss for the A6 drive line).
All these numbers and such aside.. Vararam does claim to cut .2nths off a 1/4 mile run. For 375$ thats pretty damn good.
http://www.vararam.com/sc1.html
On intake system that are pulling the air from inside the hot engine bay, your dealing with the timing retard from the launch, until the Maf sensor (has a air temp sensor in it as well) registers cool air being drawn through it maybe half track or more, and then the ECM stops retarding the timing from that point forward.
Note, if you are hot lapping, then may not be enough for the MAF/ECM to see cooler by the end the run , with timing retard the entire run instead.
Dave
