So I live in Texas...
Yeah it drove completely fine in 30. I usually book it through rain. I drove it the first day of Harvey to get to work but got worried after trekking some water and didn't risk working afterwards. When I touched the ice this morning though, back tires said "NOPE." So its best not to risk it.
slippery when wet
yea, the ride that day went fine, but as that was the first time I had
seen the DIC "ice" warning, for that 10 mile stretch, I was a bit puckered!
i hadn't planned on heading to the mountains that day. i headed north out from the san fran bay area, took I-5 and ended up in the mt, lassen park ( 315 miles later ). got back 7 hrs & 630 miles later.
i don't mind the rain, but on stock tires, no snow for me.
I drove mine to church a couple of weeks ago. It was 21 degrees. Did not push to go faster pedal, but in a gentle slow manner. The goofy DIC told me ICE POSSIBLE. Sunny, dry roads, but 21 degrees.
We live just north of AUSTIN and have experienced this recent cold weather. Our cars are parked inside an attached garage with heated spaces above and to one side of the garage, so it never drops below about 45 degrees F inside. Based on your post, I’m guessing your C6 was outside when your CEL came on. I’ve never experienced cold weather tripping a CEL, but I really wouldn’t be surprised if it did. I could see where the cold air could affect an MAF sensor or O2 sensor perhaps. The P.O. of my current ‘12 Grand Sport had installed an aftermarket CAI which tripped lean codes until I returned it to stock. I could see a 40 or 50 degree drop in temp tripping a code perhaps. Just a thought. Maybe our cars down here are like us and just don’t like freezing temps! I know it’s warm here compared to some places, but who knows? Good luck and let us know what the code was if you’re able to track it down.
With Houston gas formulation, it's possible you had some water condensation in the fuel line, it will often disappear on a restart.
I have no cel but it is 28 degrees outside and now my tag is expired. Will cold weather cause this to happen? Nothing in the OM book either about why my tag expired must be cold weather. Any help with problem?
Received 3,087 Likes
2021 C6 of the Year Finalist - Modified
I think you should take your C6 to a Chevrolet dealership and have the service department check your tag just to make sure. If it was caused by the cold weather, they will know what to do.
#34
I'm in the Dallas area, which is much colder than Houston, and never has my check engine light come on because of the cold.
#35
I was told by a Chevy mechanic some years back that the computers don't like to see rapid change, from most any sensor. What I suspect you may be seeing is that one day it was a much warmer temperature and then the next restart the outside temperature had dropped drastically, so the computer sees something it doesn't like, albeit the data was proper. I had a similar thing happen on a car years ago dropping out of the mountains of TN into AL. The drop was so quick, that the computer thought the air pressure and oxygen sensors had a problem. On the way into town, I stopped at a Chevy dealer and the service writer just laughed and told me they get about one a week stopping in with that problem, and explained it. Sure enough on the way home, the car did the same thing going back up into Chattanooga. Both times the errors cleared themselves and never returned.
The only sure fire way to check it is with an OBD reader.......if it is only one or two hits, most likely it will clear and not return. If you have loads of hits, then may be a sign of something awry.
Bear in mind (I am in Chicago) cold tends to bring out marginal problems in cars! I just had one of my cars last week see this. The temperature dipped sub-zero and my throttle body failed. The mechanic, who is a friend, said the same thing....the cold brings out the marginal failures usually...same with high heat!
#36
Received 2,887 Likes
#37
I had solved the issue as a O2 sensor issue. My car hasn't been tuned, it tripped the check engine light before it went off. Likely the col weather helped to reveal the issue as the trans fluid temp came on at 23 degrees.
#38
I believe you are beyond our help. Try trolls anonymous.
#39
#40
Ive been on this Forum a long time and every winter someone from down south will always give a weather report when some Northern member says how cold it is. Now its time for us frozen Northerners to help out our Chilly Southern Members. Things happen when its cold. Contacts that normally meet ...contract.. spark plug connectors , battery cables, any materials really. I use my car when the roads are clear so cold weather per-say shouldnt throw a code. But it will run down your battery much quicker when you are forced not to use it. In this case you need a battery tender. Your tire pressure will be down because of the cold. Spirited driving is out because of the grip capibilities of the tires are compromised by the cold. If your do get out your engine will seem more powerful because the cold air makes it so. But your tires wont like it so be careful. Dont fret.Im sure it will be back in the 80 s next week. Chin up April is coming...Oh wait ...thats for us Northern guys....
Clif
Clif
