Hi beam update
Hi beam update
Haven't seen any threads on C6 hi beam LED in a while. Anyone have success with an LED replacement in the Hi Beam position?
I did some LED fog replacement from Diode Dynamics and they are great. They do not suggest a hi beam led though.
There are lots of cheap stuff on ebay and amazon that I'm really not interested in.
Currently have an HID setup from Corvette Mods but really never liked it. Too bluish.
I'm thinking something in the 5000K range.
Any thoughts? I do live where bright lights can be used.
Subscribed
2020 C6 of the Year Finalist - Modified
C6 High Beams
I purchased A336 H9 12V/36W/3300LUMENS for my high beams. I believe I bought them from Superbrightleds. They work great however you cannot use the dust shield on the back like OEM because of the fan on the rear. Mike
I have been using the LED bulbs from JW Motorsports for 3+ years now. Like most of the other LED solutions you can't use the factory dust boots due to the fan. They are brighter, but the factory optics are so poor that honestly, it doesn't matter that much. If you are looking for better light, I am not sure you can really do much given the basic design of the high beam projector. If you are just looking for different color light, there are lots of choices ...
Former Vendor
As others have stated, the high-beams on the C6 are indeed an H9 bulb size. The main issue with using an HID setup in the high beam housing is that you won't be able to flash your high-beams when needed since they have a warm up time.
After over two long years of engineering development, extensive testing, and production tooling, we've finally released our new SL1 LED headlight replacements. They are manufactured here in St. Louis, Missouri (100% USA made!), and will do an excellent job utilizing the factory headlight's optics to maintain a safe, OEM output pattern while producing a solid increase in usable output down the road.
Our engineering team utilized advanced optical modeling software to aid in the design of the SL1.
Diode Dynamics: H9 SL1 LED Headlight for Chevrolet Corvette C6 High Beams
The SL1 is also a low-profile design, which will fit inside the factory dust cap cover without any modifications required.
Did I mention it's 100% USA Made?
We are still looking for a C6 to bring into our studio here in St. Louis for comparison photos and installation videos.
Thanks!
Nick C.
Thanks!
Nick C.
dr_gallup (01-26-2018)
Bookmarked.
Post # 7. Direct fit, utilized OEM parts, might be a good replacement.
Questions:
Yet, flash to pass, flick to Hi from low is lost (nature of Led)?
Warranty, made in USA, how long?
Yes, C6 could use a deeper wider hi beam.
A match of color and brightness to OEM lo beam could be desired.
Low beam with fogs works fairly well IMO.
End of comments....book marked.
Questions:
Former Vendor
I just noticed they weren't listed by application for the C6 Corvette high-beam, so I made a note of that for our team to create the listing as well.
They will operate in the same manner as your current halogen hi-beams. If the low-beam shuts off when the high-beam is engaged, that won't change with the SL1. They will come on instantly when flashed.
Diode Dynamics products are backed by a 3-year limited warranty.
The SL1 will produce an output pattern identical to the OEM halogen bulb, with more hotspot lux (meaning more light further down the road). For a visual representation, here's an example from our in-house photometric testing with a 2015+ F-150 reflector style headlight:
This is NOT photoshop
This is important because it won't create additional glare like other market options, which makes it safe for on-road use.
Nick C.
Nick C.
high beams
I haven't tried changing the high beams, but I did try changing the DRL/turn signal with an LED. I changed only at first, but it did not work properly. as a signal it would flash extremely fast.
I read some where that the low amp draw on the LED confuses the computer, into thinking the bulb is not working.
not an electrical expert though.
I went back to a stock bulb and a year later, still working fine.
Thanks!
Nick C.
Thanks!
Nick C.
H9 led
As I previously said the A336 from Superbright LEDS is a exact fit. There is NO warm up for flash to pass as the company on here says. About half the cost of theirs and work great. If you use the dust cover on their product where does the heat go ? As far as the DRL guys question look into Radioflyerinnovations for all of your DRL issues.
Former Vendor
Here's a video demonstrating the typical installation procedure:
Thanks!
Nick C.
Thanks!
Nick C.
Thanks!
Nick C.
Former Vendor
