2005 differential
When the axle nuts become loose the car will make a weird grinding noise when turning sharp corners slow. It is worse when the car is cold. It absolutely does not hurt the car but sounds terrible. GM made some new axle nuts that are a little different style and are only about $7.00 each. All you have to do is take off the center cap, use a huge socket ( I don't remember what size but I can go right to it in my tool box because it is HUGE) and remove the axle nut. I think I jacked the car up on each side first but cannot remember. All you have to do is put locktite on it and you are finished. It takes a whole 5 minutes for each wheel. You will have to do a forum search and there are quite a few articles stating exactly how to do it. I bought my car new and it made the noise under warranty but the dealer couldn't find the problem so i just left it until I figured it out on my own. If your car is making a grinding noise on low speed corners this is most likely your chance for a very easy low cost repair. Your Chevrolet dealer would know which is the new part because they included many other non-Corvette automobiles and GM cars.
Zo6 gears
Do you know if it's a difference in the manual Zo6 3:42 gears from the auto ? I'm looking to go with the Zo6 gears but all the gears I find shows for c6 manual trans only.
