Jacking point
Jacking point
I know the four lifting points on the sides are primarily for a professional lift. However, can you put a jack under just one of them to remove one tire at a time?
Mensan150 (02-02-2018)
The frame is pretty stiff on these cars so you can use either the front or rear shipping lock location to lift the entire side of the car. Be sure to use some sort of puck though, you don't want the jack to touch the rocker panel, it will crack and is costly to repair.
Received 1,785 Likes
If someone has a pic of the bottom of the car showing where the jacking points are, I'd appreciate if they could post it.
The following 7 users liked this post by lawson1603:
bothred (02-06-2018),
CaPilotMark (02-04-2018),
GettnBetter (02-09-2018),
Jeff T. (02-09-2018),
Mensan150 (02-03-2018),
and 2 others liked this post.
Interesting. I had heard just the opposite. Makes me wonder. Having the doors, hood, and hatch open I mean.
The following 11 users liked this post by EVRose:
74plb (02-12-2018),
dr_gallup (02-09-2018),
ErikR (02-02-2018),
FatsWaller (02-02-2018),
and 6 others liked this post.
EVRose (02-02-2018)
Best photo of jacking points ever!!! Not too often something completely new shows up here.
Thanks for the laugh EV!!
EVRose (02-02-2018)
Received 4,712 Likes
No need to worry about closing or opening doors when jacking up a C6 Corvette, the frame is seriously stiff & you can open & close your doors at will
I wonder if he'd be interested in selling his headers
When jacking up the front or rear of the car, the points are shown in the manual and in the pictures:
Front lifting points
Front lifting point closeup - span across points with block or pad on both sides
Rear lifting points
Rear lifting point closeup - span points with block or pad on both sides
Rear lifting points
