2007 Corvette RPO codes
Hello all, I hope you are doing well.
This is what I found today after looking around here on CF for the trim and options I wanted to know were installed at factory on my Corvette. My thanks to members who posted comments and links to the RPO sticker in the glove box. The codes tell all to the specific Corvette build. Here is what I found for mine in this report and for my archive.
Picture of sticker:
Good to know just what we have on our Corvettes, right? For used Corvette buyers like myself, this webpage that provides the specific options, trim and packages on the car is invaluable. I will add a breakdown of the codes to my sticker in reply to this next for my archive.
Thanks CF members for the tips. I did not know till now I had the Z51 package. Best C
Picture of sticker:
Picture of sticker:
Picture of sticker:
Here is the 2007 specific Corvette RPO codes webpage : https://www.corvetteactioncenter.com.../2007rpos.html I found this very informative!
AJ7 Restraint System - Seat, Inflatable, Driver & Pass, FRT & Side
AQ9 Seat - FRT BKT, Luxury
BGR Plant Code - Bowling Green, KY, USA
CJ2 HVAC System - Air Conditioner FRT, Auto Temp Cont, AUX Temp Cont
CM7 Roof - Convertible, Folding, Power
DD0 Mirror O/S - LH & RH, Remote Control, Electric, Heated, LT Sensitive
DD8 Mirror I/S R/V - LT Sensitive
FE3 Suspension System - Sport
FE9 Certification - Emission, Federal
GU6 Axle Rear - 3.42 Ratio
JL5 Control - Manual Trans, First To Fourth Gear Skip Shift
J55 Brake System - Heavy Duty
KA1 Heater - Seat, FRT
KNP Cooling System - Trans, HD
KPS Cooler - Oil, Engine
K63 Generator - 110 AMP
LS2 Engine - Gas, 8 Cyl, 6.0L, SFI, Alum, GM
MN6 Merchandised Trans - Man 6 Spd Provisions
MZ6 Transmission - Man 6 Spd, Tremec, 85mm, 2.97 1st, 0.57 6th, O/D
NK4 Steering Wheel - Sport Leather
NT7 Emission System - Federal, Tier 2
N37 Steering Column - Tilt Type
QX3 Wheel - 18 X 8.5 FRT & 19 X 10 RR, Chrome, Flangless
UG1 Opener - Garage Door, Universal
UJ9 Indicator - Low Tire Press, VAR 2
UK3 Control - Steering Wheel, Accessory
US3 Antenna - Diversity
US9 Radio - AM/FM Stereo, SEEK/SCAN, RDS, Multiple Compact Disc, Auto Tone Control, Clock, ETR, MP3
UV6 Display - Head Up
U2K Digital Audio System - S - Band
U52 Cluster - Inst, Electronic
U65 Speaker System - 7, Custom
VDD Vehicle Information - DVD, Customer Orientation
VK3 Licence Plate Front - FRT Mounting PKG
V73 Vehicle Statement - USA/Canada
Z51 Performance Package - Handling
3LT Package LT Option 3
41T Top Color - Black (96)
airspeed (02-04-2018)
rpo codes
thanks foe RPO codes had my 07 for awhile saw that sticker but did not know what they meant now I know what the car was built with thanks to CF members for all the knowledge I have learned so much by just reading different posts.
chrisarnold2u (02-05-2018)
Greetings from Frozen Canada!
Looking at my RPO sticker in the glove box of my 2007 Corvette Ive been able to de-code all the options except for this one.
Does anyone know what this one is for or is in regard to?
KDMPZF
Thank you!
KDMPZF
Thank you!
Race Car Tech
Thank you!
Jim
corvettemuseum (01-18-2019)
