Who's going to change to the Mobil 1, 0W-40
#41
I have used the 0W40 for years with no problems with the high temps here in Florida it works well. I change it at 50% on the OLM to be sure it holds it's viscosity and I think it is the best of both worlds. I have also used 5W40 mixed fleet a few times in the Summer since it has more zinc.
Not saying anyone should change a program that they're comfortable with. Just my thoughts on it.
http://www.billswebspace.com/mobil_1_product_guide.pdf
#42
Received 2,478 Likes
St. Jude Donor '15
"In honor of jpee"
As to the "backward compatible" for the new, recommended oil for all C7s (2014-2019) of 0W-40, it is a different oil than the currently available domestic or Euro version. Whether it's better or not, Chevrolet and GM are recommending it for all C7s.
One person in C7 said it was ALSO backward compatible to ALL Dexos-recommended Corvettes. Dexos started with the 2011 C6s. So, I asked the question: where does it say that from either GM or Mobil1? So far, it doesn't. I was directed to the Tadge post, it doesn't say it either.
As far as I've seen, GM has not said the new 0W-40 is for C6s of any year, '11 before or after. It may work well, but the question always is: for how long? I trust Mobil1 but they don't offer any warranties. GM does, or used to if the one on your car has expired on your C6. GM also wrote the book on what to use in it. Until that changes, it's your independent call as to what to use.
And to the post that "LDB" made, what he's saying makes sense, but for him and others, the details on the newest Mobil1 oil are not in published print. So, all we are reading is a marketing piece from the oil company. I'm not saying it's untrue or shades the truth but there are some missing pieces of information---for LDB and for me, as well as others on this thread.
#43
I've read on the Internet that it is best to use a straight 30W in a '53 Buick so that's what I'm sticking with.
#44
There could be a big difference!---the C7 engines are completely different from any C6 engine which could lead to a completely different set of tolerances to accommodate higher horsepower, torque, etc. Time marches on---no one would say a '60s, '70s or even '90s car has the same tolerances as a car made last year or 5 years ago, are they?
The following 2 users liked this post by LDB:
dmk0210 (02-26-2018),
Larry Myers (02-25-2018)
#45
In my vehicles I use the Mobil 1 Extended Performance oils. My Z28 has 344,000 miles on the Original motor using 10w-30, I change it every 9,000 miles or so and I use the 5w-30 in my 08 LS3.
On another note I replaced the top end on my Z28 at 265,000 and the only visible signs of wear was on 2 of the pushrods on the end connecting the rocker arm, the Chrom-moly shine was gone. That most likely was caused by a piece of dirt getting lodged in there somehow, at least that is what someone has told me as to why it was only on one end of 2 different pushrods. Good info. and thanx to old motorhead for the Chart.
#47
Received 1,136 Likes
Were both oils checked under the same conditions? i.e.: A cold idle? Warm idle? Cold highway speed? Warm highway speed?
Either way, that oil isn't going to make any noticeable pressure difference over the previous. If anything, it might be slightly lower when cold, not higher.
#50
Received 2,093 Likes
#52
"Oil pressure should be 20 to 80 psi (140 to 550 kPa). In certain situations such as long, extended idles on hot days, it could read as low as 6 psi (40 kPa) and still be considered normal"
#53
... as you go above 250, the 0W40 will thin out less and thus be better for all engines that are pushed hard enough to get the oil that hot. But there is a risk. The risk is that to get to that wide a spread between W and normal number, the oil needs VI improver additive, and those additives have not historically been very stable. If the additive fails, the 0W40 will degrade to about 0W25. ....
High heat or long service interval?
I only put about 4k to 5k miles on my oil changes and change it once a year and don't let my oil temp gauge get above 250-260 deg. Is there a realistic risk that the VI improvers additives would fail during those short OICs?
#54
I said the same thing in reply 25 but added the low pressure warning light doesn't come on until 3 psi.
owc6 (02-26-2018)
#55
5W30 has worked in my 08 since it was born 10 years ago. I don't see any need to change what's already proven to work just fine.
#56
What are the conditions where you would expect the VI improvers additives to fail?
#58
#60
You don’t seem very interested in how things work. That’s fine with me. I’m not trying to jam anything down anyone’s throat, I was simply trying to answer a question. Is your suggestion that I should not answer questions, or that I should give better answers? If the latter, what would you suggest I should have said in answer to post #53?
