Gear change
Gear change
I have a 2012 auto and would like to change rear gear from 2.59 to 3.24. Has anyone done this? if so, cost for: Parts
Labor?
I live in Rio Rancho, nm. I am a 100% disabled combat veteran and need a shop to do the work, so if anyone has a good shop in area, PM me with name, address, etc.
Thx
Labor?
Thx
Received 2,060 Likes
Labor?
Thx
Labor?
Thx
Pro Mechanic
Received 3,938 Likes
Labor?
Thx
Labor?
Thx
you may want to check the regional area of the forum for advice on a shop in your area, link below....................
https://www.corvetteforum.com/forums/southwest-44/
Received 4,689 Likes
A better solution would be to leave the stock gearing as is & change out the torque converter to a higher stall speed...the car will drive like stock with normal driving but mash the throttle and you will find the best "bang for the buck" mod for your A6 car, and this mod will be cheaper than a gear swap...the A6 final drive gear ratios are actually better (lower) than the M6 trannies, many posts here listing the ratios
c6 gear
Labor?
Thx
Labor?
Thx
I think you have a good set up as is. Not sure the rear change is worth the cost or will make that much difference with out doing other mods. Thank you for your service to our country. Glad you can enjoy Corvette!
