C6 Top End Noise
C6 Top End Noise
Morning All,
I have a 2013 C6 Base model. This past Friday it recently developed a metallic clanking noising on the top end that goes with the RPM. Sounds like a lifter has collapsed. I've left it with the dealer as it still has a "Certified Pre-Owned Powertrain Lmtd Warranty".
I was able to have the dealer pull the service records on it.
~1,400 miles it states "Engine Replacement"
~1,480 miles it states "Lifter Replacement Both Sides"
~2,000 miles it states "Lifter Replacement Both Sides"
Car now has ~82,000 miles on it and in 18,000 miles the warranty is up.
My concern is that the dealer will have an issue with headers that are on the car and it being so close to the warranty expiration, I think they might try to deny my warranty claim.
But given that the car has a "record" of lifter issues, I can try to leverage that.
Has anyone had any issues like this with the warranty or any lifter issues within their LS3 that's bone stock besides headers?
Thanks,
Jordan
Thanks,
Jordan
Morning All,
Thanks,
Jordan
Thanks,
Jordan
Find out if it has a tune because it probably won't matter about the warranty then. They won't care about a lifter issue 80k miles ago if it has been tuned since then. Is the noise when it is cold because the LS3 isn't a quiet motor, especially when cold.
First engine replacement itself would not set off buying the used car when looking at the GM service history and carfax report before buying the car, but the recurring lifter problems the engine replacement screams that when the first engine blew, it left metal partials in the oil coolers and lines, they where not replaced with the new engine, and it kept sucking the metal partials back into the engine over and over again.
So from 2K to 80K is a long time, but the inital repeat lifter problem over and over again in only 600 miles to start with, does make you wonder on what the metal partials did in that amount of time that where not caught in that first 600 miles.
As for the car being mod'd (had to be re-tuned for the headers) that pretty much just voided a warranty on the motor from GM, and your only saving grace with a aftermarket warranty is if you bought the car that way to start with, and what the aftermarket warranty was based on to begin with isntead.
Received 3,626 Likes
2016 C6 of Year Finalist
They never showed me a Dealer History report when I bought the car (Rookie move on my part).
Guess we shall see if the Dealer takes pity on me at this point.
It has a tune on it. It doesn't matter if the motor is cold or warmed up, the noise is there.
CarFax showed up clean when I bought the car. Even though I spoke with previous owner a year later and he said it had been in a accident prior to trading it in.
Welker1 (03-22-2018)
~1,400 miles "Engine Replacement" ~1,480 miles "Lifter Replacement Both Sides" ~2,000 miles it states "Lifter Replacement Both Sides"...Car now has ~82,000 miles on it
Whatever's causing it, it's there. In the day car would be considered a lemon for repeated repairs on same component(s).
Bad news is:
...in 18,000 miles the warranty is up...My concern is that the dealer will have an issue with headers that are on the car and it being so close to the warranty expiration, I think they might try to deny my warranty claim.
It'll be the tune, tipped-off by headers they'll surely check.
Most every member here w/ a Corvette under either B2B or extended warranty knows all too well a tune invalidates coverage. At least if the problem lies w/ motor, anyway.
Guys get a tune, develop a issue, try having it covered, denied.
Driven an '08 Z06 for 10 years, bought it new.
Since I've maintained either a GMPP or now GMEPP the thought of tampering w/ tune was out of the question. New LS2/3 are a bargain compared w/ a new LS7.
G/L, keep us posted what dealers says. Would love being wrong.
Received 2,887 Likes
Have you tried changing oil and filter?
My car starts making lifter noise when OLM gets around 45%. Even more pronounced with cold temps. Fresh oil and filter quiets it down.
High mileage 07, 300 miles shy of 200,000 so little ticking is to be expected. BTW headers and tune done in 07 by LG Motorsports.
Sounds like you might have bigger problems than I but fresh oil never hurts.
Spoke with the Service Manager yesterday, stated he would replace it under warranty. Apparently the #7 lifter(s) were sticking...
Curious how the head, cam, pushrod and rocker arm look after the pushrod was banging around due to the sticking lifter...
Also stated I had "massive exhaust leaks" due to the headers which is news to me, I think I would have heard the leaks before my issue happened.
Landru (03-28-2018)
Thanks for closing this.
A(nother) lifter. Who knew.
Wondering whether saving up the dust for a new set of heads wouldn't make sense considering track record. Got lucky, this time. Next time be prepared.
Associated component damage?
Guessing you'll hear it if there is, or not.
JordanRN (04-02-2018)
Service report in my possession...
Camshaft, Head to Machine Shop, Lifters (Both Sides), Top End Gaskets, Water Pump, Front Cover Gaskets, Oil Pan Gasket, and Thermostat...
My question is, do I ask for a new motor because of the all the metal particles floating around? I do not want to be sitting on a ticking time bomb.....
Good luck
Get a plan together to trade this car to a Chevy dealer. Put a date on execution in your plan.
And should dealer try jacking you around w/ car's history?
Remind 'em what they paid fixing it, tell 'em it's better than new.
Their SD said so.
It'll be reliable for enough years to have a plan ready to launch, regardless financial state. For now enjoy why you bought it.
C6 of any MY/trim's a beautiful ride, when they function.
G/L
