Brake line vent thread
Putting new Stop Tech stainless steel braided brake lines on my 2013 Grand Sport. During my coilover install, I peeled a track turd off one of the OEM brake lines and found a split in the outer sheathing. No worries, bought 4 new lines and went the ss braided route for added protection.
I’m sure many are aware of the factory over-tightening the occasional line which then deforms the fitting. Lots of threads on this since 2005. Apparently I got the monkey at Bowling Green. All 4 of mine are deformed. What a PIA.
That’s all...just needed to vent
It would make sense that all 4 of your brake fittings were identically over tightened if the same mis-calibrated tooling was used on all 4.
From what I've seen in multiple visits to Bowling Green the assembly employees are not responsible for the torque on critical components. It's the tooling that provides the correct torque spec. If the incorrect torque is applied to one of these fasteners it's not the fault of the assembler operating the tool, it's the fault of whoever's job it is to maintain that tool.
Still a PIA that a task that should take barely an hour will take much longer than that.
So what are you going to need to do to correct it? Replace a bunch of brake lines? Is it possible to fix the existing fittings?
