Auto Door Lock system
The instructions are on page 5-59 of the owners manual. If you don't have one, you can download the PDF version here:
https://my.chevrolet.com/content/dam...tte_owners.pdf
Press the OPTION button until
PASSIVE DOOR LOCKING appears
on the display, then press the
RESET button to scroll through the
following modes:
. OFF (default)
. SILENT
. HORN
If you choose OFF, this option will
turn off.
When the mode you want is
selected, press the OPTION button
to set your choice and advance to
the next personal option.
following modes:
. OFF (default)
. SILENT
. HORN
turn off.
2nd Gear
aUTO lOCK dISABLE
[QUOTE=Welker1;1597061848]The instructions are on page 5-59 of the owners manual. If you don't have one, you can download the PDF version here:
https://my.chevrolet.com/content/dam...orvette_owners.
Thanks so much. I read thru the manual several times and did not see that. Also, appreciate the PDF file.
Have a great day.
rick
Have a great day.
rick
Welker1 (04-24-2018)
Forgot to mention that you must be using a fob that's been programmed for the car as fob #1 or fob #2. Only those 2 fobs have access to memory options. Doesn't matter what number is engraved on the fob, it's how it was programmed for the car.
[QUOTE=Vette_DD;1597065128]
And if you do have 2 fobs programmed as a #1 and a #2, you'll need to disable 'auto-lock' for each fob separately.
