Drivers Seat Inop.
St. Jude Donor '08
Drivers Seat Inop.
My drivers seat has been intermittent for awhile and finally stopped altogether and was all the way back. I searched through all of the other threads on this issue and found one where you could unplug the forward and reverse motor connecter and jump 12 volts to it to get the seat forward. I found this to be difficult to do since you can barley reach in there and disconnect the connector.
I ended up removing the seat switches. The seat cushion has grey cloth around the bottom of the seat cushion with a cord inside that secures the cushion to the seat frame. I cut the cord with a razor knife and then I was able to lift up the seat cushion to get to the seat module. Once back together you will not notice that you cut the cord, as the side switch cover will hold it in place.
I connected the new connector to the seat module and applied 12 volts to move the seat forward to get to the rear seat bolts.
The seat module is mounted on the seat springs and when you sit in the seat the module moves with the spring and this flexes the power wires. The power wires are 10ga and have a low strand count and do not flex well and eventually break off at the connector. I wire tied the power wires to the seat spring so that the wires move with the module when you sit in the seat. The seat was repaired once before I purchased the car.
Landru (05-01-2018)
Nice write-up, even better it's back working.
Wondering if Chevy's 'comb' contraption was supposed to address this & associated problems w/ wires breaking/coming loose w/ repeated seat movement.
Glad you're golden again, here's to running this down.
I'm sure you did this prior, but if others have a problem with seat operation, the first thing to do is separate the connections, lightly brush the receptacles, then use compressed air to blow out any dirt or other particles. I had a problem on my 08 (sold since) with an intermittent seat belt warning when there was nobody in the seat, and vertical adjustment, in the passenger seat. Did the above, and it was fine after that.
St. Jude Donor '08
