wanted to switch lanes and lost control a bit
b. I don't care enough to research this any further. But feel free to educate...I certainly don't mind being wrong and getting smarter from it
c. regardless of which is semantically correct, everyone and their brother knew what the hell I was talking about
Received 1,789 Likes
If they are part of the problem, it's spring now, so when you say 'next spring', do you mean a year from now? If your tires need to be replaced because they are old and 'have lost their grip', I wouldn't wait a year to replace them. You might plan to drive easy, but with the clowns out there driving around, you never know when you're going to need to pile on the brakes.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
next spring? like 2019? yes, drive conservatively and don't worry about handling in an emergency situation, when you need your tires to be top notch. they won't be.
if you think I'm wrong about my un-optimistic analysis, reread Icecap's post. my guess: he needed great tires and great active handling, abs, traction control, etc. to make it out of that one ALIVE.
[QUOTE=slowstang305;1597180813]This is 100% true. Drive carefully, slow down and take it easy in adverse conditions. The car did what it
It was 56 degrees. You are absolutely right about "slow down" etc., but the conditions were not adverse, unless the OP left something out other than temp.
I just hope the OP does not press that little button, because he may not be ready for it....
Received 1,596 Likes
I do not think Engineers will use the term "ft-lbs" anywhere because it would be extremely confusing, the letter "s" means seconds and the unit of power using ft and lb looks like this: ft-lbf/s notice that it is divided by seconds to get power.
1 Horsepower is 550 ft-lbf/s which is 746 Watts.
I can appreciate what you are trying to do just not how you are doing it (no explanation and seems motherly)
First, In fluid mechanics there is an immediate distinction between lbf and lbm, that is, pound force, and pound mass.
If you wanted to, you could say ft-lbf, "the fundamental unit of work in traditional system is the foot-pound" -page 11, eight edition, fluid mech.
Second, in other fields of engineering, they sometimes write a ft-lbf term as this: lbft or lb*ft, it means the same thing. pounds is being multiplied to feet, and both are over 1. And because multiplication, we can also say ft*lb or ftlb to the same result. It would be acceptable that way depending on the field.
Finally, IMO I dislike the use of "-" between ft and lbf because that makes it look like a minus sign is being used. When solving for solutions you wouldn't want the minus sign hanging around. Just be aware ft-lbf and ft-lbf/s is actually [(ft*lbf) / seconds] or feet times pound force all over seconds.
