Can these be fixed?
Can these be fixed?
Took the car out for a drive today and went through a mini dust storm. When I got back to the house I was looking for rock chips on the front of the car with my flashlight and noticed there is spider webbing on the front bumper that I never noticed before. I imagine it has been there since I bought the car but I've never taken a flash light to the car so I probably didn't see it until now.
You can see from the picture with the flashlight on the spider webbing shows, but with no flash or anything you can hardly, if at all, see any spider webbing.
What causes this? Is there any way to fix this? Will it worsen if left untreated?
That looks to me like the front bumper had some sort of impact at one point. If it's the actual clear cracking then I don't see how it can easily be fixed.
Could be...the car had 24,500 miles when I bought it. No accident damage reported, though it doesn't mean it wasn't hit by a flying piece of something on the highway one day. What else could cause this? For example, if you dropped a tool onto the nose could that potentially cause this too? It's got the spider webbing right on the point of the nose and then on the front right edge and front left edge of the bumper too. You can't really see them unless you're shining a light on them. If they won't get worse over time then I'm okay leaving them. But if they can't be fixed and they will get worse I guess I'll be buying a replacement bumper down the road
I agree. Had to be a slight bump. Could have been tapped in a parking lot. Maybe a tall 4x4 hit it, square on. The bumper will deflect quite a bit and return to original shape, but the paint, even though flexible, will only go so far undamaged.
Spider webbing like that is usually the entire thickness of the clear. Hopefully not the base coat, but you won't know until all the webbing is wet sanded out. If just the clear coat and the base is OK, it might not be that big a job.
I had similar spider-webbing after a whitetail doe impact my bumper a few years ago. Hard to see but I saw it every single time and couldn't leave it that way. Had an expert body shop/paint guy take care of it and so glad I did.
Received 3,628 Likes
2016 C6 of Year Finalist
