Please help with the correct Radiator Shroud part number
2013 Base Coupe, M6. I'm going to install a Z06 oil cooler, already purchased from a forum member.
I want to install a new Radiator baffle (shroud) that has the holes required for mounting the Z06 oil cooler and lines, 6 holes total in the shroud.
I'm confused about the correct part number. Is it:
25857217 OR 20981755 ????
Can you explain the difference between the two?
Thank you in advance for your help!👍
