Rear Axle drain plug removal
Kingstonontario (06-05-2018)
It's an unimaginable pain in the **** for certain years. I have a 2009 Z51 and it was not easy to access at all. Other years are cake frim what I understand. I think it all depends on which diff you have.
Use a ball hex extension. Piece of cake.
I thought they had moved the drain plug in 2006??
At any rate, you can try a ball-end hex-head but that did not work for me. The plug was way too tight. So I decided to get the spring out of the way. It isn't hard, just adds a bit of time. Watch the first part of this video.
Retired & lovin' it!
Had the same problem when I did the gear oil change on my '05. Solution was a 3/8" hex key....cut a bit off the short end so it would clear the spring & fit the drain plug. Then a piece of pipe to provide leverage on the long end. Another option is to cut a short piece of hex rod (maybe 1 inch) to fit the drain plug & then use a box or open end wrench to remove the plug.
