C6 Full Bi LED Morimoto C7 Style Replacement Headlights from Umnitza WITH photos and
#202
In the last couple of videos you just posted, is that set with your harness that you made?
#204
Also, whatever happened to the DRLs going half brightness (or reduced brightness) when the turn signals are applied? It might be doing it, but it's hard to tell in the videos. Just want to confirm.
Thanks.
#206
Installed these last night. Very straightforward. Will be easy if you have removed your headlights before. If you haven't then that part is a pain in the *** to figure out the first time.
Wiring is plug and play for the new setup with the included harness, very easy.
nmalik3000 (07-17-2018)
#210
more pics please!!! Different angles!
#211
Anthony,
Can you shed more light (no pun intended!) on the following comment you made on your IG post:
You stated:
"they can be disabled or turned off or put on a switch, your call."
So you can have the "L" shaped DRL on the corresponding headlight turn off while the turn signals are flashing? What's involved for that?
You stated:
#212
Delivery update
This shipment cost $1800 by air for only 10 units. It would be been $2400 for another 10 units but they were not ready in time.
ALL the remaining sets are being put on a boat next week - Tu/We/Th not sure which of those days.
This includes tails.
Something written to a customer private should be stated here:
PS: the lights look much much better in person and the light smoked lenses are seriously a non issue in person, the camera simply doesn't show it well.
Thanks!
#213
Supporting Vendor
Jeff et al.
We will know more tonight about the availability of the shipment. As you can see, we had the added benefit of being on the west coast, so ocean shipments usually only take 2 weeks on the water and 4 days to clear and unload.
We had originally expected ALL the items to be here end of July, but the factory just said they will probably get them out early next week.
#214
PM sent to you. I would like to see if I can meet up with you and see them in person.
QUOTE=ledesordre;1597612666]Installed these last night. Very straightforward. Will be easy if you have removed your headlights before. If you haven't then that part is a pain in the *** to figure out the first time.
[/QUOTE]
[/QUOTE]
#215
Anthony,
https://www.instagram.com/p/BlUUCXQDOkD/
You stated:
You stated:
#216
Supporting Vendor
There is something included with our lights. I have no idea if the other guys are getting it too. In any case the way it is done tuen signals will dim the hockey stick by 50% same for parking lights same for headlights
#218
So the dimmer for the white L shaped will be included, but the harness to make the white L the DRL is sold separately? Is what is being said here?
